EAGLE User Support (English) Flood bridging pins
  • Views 869 views
Flood bridging pins
Hi, I most likely have some setting, setup incorrectly, somewhere but I
cannot seem to figure out why the flood fill is bridging adjacent pins
vs running out traces to the flood?
https://gyazo.com/26b9899508a3cf38d74d07ffebf9eb3a
Any suggestions on hat to check?
    autodeskguest over 9 years ago in reply to dukepro
    On 10/25/2016 8:33 AM, Chuck Huber wrote:
    On 10/24/2016 12:11 PM, Glenn Jones wrote:
    On 10/24/2016 12:07 PM, Glenn Jones wrote:
    On 10/24/2016 2:46 AM, Rob Pearce wrote:
    but I
    It looks like the "width" of the polygon (which defines the
    thickness of
    the lines it gets drawn with) is bigger than the width of the SMD pads,
    by quite some margin. Eagle probably can't meet the clearance and
    thermal separation rules with a polygon that thick.
    Hi rob, thanks that helped a lot. Now traces are automatically coming
    out of both ends of that pad which is what i want but they are still
    bridging across the center of the pins as well.
    Would I use a small restrict polygon to prevent that?
    Glenn
    Well not sure if that's the best way but a small restrict polygon
    gives me the desired effect.
    https://gyazo.com/92ec251ca1443faaa0333c266c46683f
    You might also try a short restrict line on the right end, essentially
    cutting off the fill from the right.  This will avoid all the drc errors
    generated from having the SMD pads falling within the restrict polygon.
    Looking at the second pad from the right, the bottom connection is
    different from all the others.  Was this pad partially routed with a
    larger wire?
    HTH,
        - Chuck
    Hi Chuck this is what i have have now. I cleaned up that extra wire I
    added before.
    https://gyazo.com/6b906f927ffaf72e1a3bd604ac42dac2
    Glenn
  • dukepro
    dukepro over 9 years ago in reply to autodeskguest
    but I
    thickness of
    Glenn
    larger wire?
    HTH,
        - Chuck
    It looks like the "width" of the polygon (which defines the thickness of
    Glenn
    Well not sure if that's the best way but a small restrict polygon gives
    Glenn
