EAGLE User Support (English) Gateswap across schematic   sheets
  • Replies 13 replies
  • Subscribers 187 subscribers
  • Views 2104 views
I just discovered GATESWAP only works within the current schematic sheet.
I am using a quad opamp.  IC10A and IC10B are on schematic sheet 9, and
IC10C and IC10D on sheet 10.  Now that I'm placing parts on the board, I
want to swap IC10A <> IC10D and IC10B <> IC10C.
In the schematic editor, I went to sheet 9 and entered "gateswap ic10a
ic10d".  This resulted in the rather unhelpful pop "Can't swap gate IC10A
and IC10D".  Why can't these gates be swapped?  I checked the swaplevel of
each gate.  No, they are all set to 1.  Maybe the gate names need to be
enclosed in apostrophies?  No, that didn't help.  Upper case?  No, that
wasn't it either.
Then I tried "gateswap ic10a ic10b".  That worked.  OK, maybe I had a small
typo.  Using up-arrow, I got the previous command back and carefully
changed only the B to a D.  Now its back to "Can't swap gate IC10A and
IC10D".  It must be that gate A and D are on different sheets, but that's
not intuitive at all.
I got around this by moving all of the sheet 10 contents to the side of
sheet 9, doing the gateswaps, then moving the sheet 10 content back to
sheet 10.
Am I missing something?
If not, then here are my suggestions:Allow GATESWAP to work across
schematic sheets when entered as a command.
Fix the GATESWAP error dialog to explain why it can't swap the gates as
requested (incompatible swap level, different numbers of pins, no such
gate, not allowed on Tuesday afternoons, etc).
If you don't do #1, at least mention this limitation in the GATESWAP help
page.
    On 12.11.2016 01:40, warrenbrayshaw wrote:
    On 12/11/2016 8:35 a.m., Jorge Garcia wrote:
    On 11/11/2016 5:01 AM, Morten Leikvoll wrote:
    On 10.11.2016 18:24, Jorge Garcia wrote:
    Do you guys have any ideas? If we can have a suggestion of what should
    be implemented then that gives direction for the devs. How would you
    guys want this to work?
    I don't think there are hierarcy issues with the command line syntax
    Olin suggested. Gate swapping across hierarcy can be done with
    reference to "[module_instance_name:]gate_name" (the format that is
    listed under allparts() loop member in ULP). The colon character is
    already illegal as refdes, so it should be easy to resolve this. It also
    works with deeper modules.
    I agree with you, however I don't think the GATESWAP command currently
    supports using the module name, it's not documented at least.
    Gateswapping between different levels of the hierarchy would get messy
    fast although a read of Warren's suggestion gives a work around.
    I'll create an enhancement report with Warren's suggestion, since it is
    the most detailed and addresses a few corner cases.
    Let's see what the devs do with it.
    Best Regards,
    Jorge Garcia
    There is one case that has not been mentioned so far:
    You can currently gate swap gates that are not in the same device so
    long as they are equivalent. The HELP describes the rules for this.
    So one should be able to choose from those gates also.
    Warren
    There is a very special case to look out for:only devices powered with
    the same power rails should swap gates! This may be a bit difficult to
    verify, since there is no direct relation between gates and their supply
    pins. Assuming that all gates are powered by their devices their 'pwr'
    pins is maybe a good approximation, but it's not covering all cases.
    I guess the current function is to not care about power nets?
    Best Regards,
    Jorge Garcia
    Warren
    Jorge Garcia wrote:
    On 11/10/2016 2:17 AM, Lorenz wrote:
    It is clear why "gateswap (x1 y1) (x2 y2)" won't work across sheets
    (at least the clickety-click way, and the command line version would
    require an extended coordinate syntax), but ...
    ... I can't see any reason why "gateswap gate1 gate2" should pose any
    implementation problems.
    Under the current Hierarchy implementation there is the possibility for
    ambiguity with the command line syntax.
    some (additional) thoughts (but remember I'm still using 6.6 and have
    only played with 7.x briefly)
    1) gateswap inside a modul should pose no problem as it doesn't
    outside modules.
    As long as you are on a module page (or one of several belonging to
    the module), there is no ambiguity regarding parts of the module.
    Doing the gateswap from a page not belonging to the module would need
    an extention of the naming syntax though (say: module_name:gate_name),
    but I don't think that's required at all.
    2) gateswap across instances of modules makes no sense too me.
    Afterwards the instances wouldn't represent the same module any more
    I don't think it's possible and neither should it be, to use say one
    half of a double opamp in one instance of a module and the other
    half in a second.
    Disclaimer: I'm using 6.6, don't know if 7.x allows it.
    Just to clarify it still doesn't allow it.
    I'm of the opinion that a gateswap in the board would be most useful.
    Usually you decide to swap a gate because you are on the layout and
    realize using a different gate would simplify your routing task.
    The problem I see is that I can't think of what the user interface for
    that would be like. Now in current V7 we have to deal with how hierarchy
    is implemented and that confuses a lot of things.
    3) if gateswap using the gate name syntax would work in the schematic,
    I think it would be easy to create an ULP to at least experiment with
    gateswap from the board editor (It's not possible to select pins in
    the board editor, but you could group the part or parts and one net of
    both gates involved and figure the rest out in the ULP).
    lorenz
    Best Regards,
    Jorge Garcia
    Warren
    Best Regards,
    Jorge Garcia
    When it comes to GUI, I suggest (from sch)
    Click swap gate, click the gate you want to swap.
    [If the clicked gate is inside a module, list all the module instances
    and let the user choose wich one to swap.]
    Now bring up a list of other gates within the selected device (maybe
    with their page# listed), then select wich one to swap with.
    If you want to support this from brd in a future version:
    Command line can be identical to sch.
    For GUI, click swap gate, click part, list gates + pin#'s belonging to
    the gates, pick one to swap, and the one to swap with. There are several
    usable ways to format this. A version further down the line can improve
    this even further with dynamic highlighting and other visual effects.
    I need to play more with multiple sheets before I understand that.
    Agreed.
    Definitely at the board layout level. Makes the most sense there
    from my perspective.
    For the board GUI interface, I humbly suggest
    1.  click on gate-swap. Would be nice to highlight device pins
    corresponding to swappable gates at this time - but the user knows
    which device anyway -- and it could get pretty crowded with many
    eligible devices;
    2. click on one gate pin and the other "eligible" pins are
    highlighted so that the user can easily see to select the
    (functionally) equivalent pin on another gate;
    3. click on one of the highlighted pins to finish and update the
    corresponding schematic.
    Finished.
    A different implementation would be to show the gate objects on the
    device at board level with connections and to let the user click and
    drag a gate objects to swap. But that changes the interface
    paradigm.  V10.1 perhaps. image
    /"\ Bernd Felsche - Somewhere in Western Australia
    \ /  ASCII ribbon campaign | For every complex problem there is an
    X   against HTML mail     | answer that is clear, simple, and wrong.
    / \  and postings          |  --HL Mencken
    I feel it should work in a manner very similar to the current pin swap in
    the board editor.
    The following assumes the user has already determined the name of the two
    gates to swap.
    By mouse:
    Select gate swap icon (new).
    Left click on a pin of a gate that will be involved in the swap.(Just as
    you currently do with pin swap)
    Dialog appears listing all gates with the same swap level as the gate (pin)
    you selected.
    Click to select that gate.
    The display is modified as pin swap does but now there are multiple pin
    swaps that will need tidying up.
    'Cancel' in this dialog should mean swap the first gate with
    itself.Currently Eagle does not let you swap a gate with itself.
    By command line:
    No change needed if you know the two gates to be swapped.
    GATESWAP gate_name gate_name..;
    GATESWAP gate_name
    This would display the same dialog as by mouse to select the second gate.
    Within a script this scenario could well be invalid unless it is the last
    line of the script.
    As above, 'Cancel' in this dialog should mean swap the first gate with
    itself.Currently Eagle does not let you swap a gate with itself, but by
    swapping to itself,the script always continues with a valid gate name.
    At the beginning of the work flow the user will likely have right clicked
    on the element and selected 'Display Device' as a method of confirming the
    gatename/pins of the gate they wish to swap with.
    A deluxe implementation would remove this step as follows:
    By mouse:
    Dialog appears with an image displaying the device view as you see it in
    the library (This is the deluxe bit)
    and also listing all gates with the same swap level as the gate (pin) you
    selected.
    The gate swap being initiated from the board is, in fact, a change to the
    schematic. The swap can be done blindly from the board without reference to
    the schematic because the gates will always be identical, controlled by the
    swap level when the library was created.
    Board only design:
    For a board only design the above should work without the need for a
    schematic to be updated.
    Modules:
    For modules, if you change the layout instance of one module, with a gate
    swap, all other layouts of the same module should reflect the change as
    there is only one schematic for each module type on the board.
    If users desire to be able to swap gate on only one of the modules then
    that layout instance would logically need to be the layout for of a another
    module of a different name. That new module (schematic sheet) could be
    created and would only need to be cloned further when there is more than
    one in use so that multiple changes to one module would not generate a new
    module each time. This could be achievable but some users will run into
    problems due to limited sheets being available to them.
    Module part naming issues;
    I cannot see that there would be any ambiguity using command line. Parts
    within modules can be identified by name. When you know the module name you
    can deduce the part name in the module schematic once you determine the
    naming notation used.
    HTH
    Warren
    Jorge Garcia wrote on Thu, 10 November 2016 12:24
    any
    I haven't used hierarchy, so don't understand the issue.  What about
    hierarchy makes "IC1A", for example, ambiguous?  Is it that there can be a
    IC1 in each of several sub-blocks?  If so, then that must cause trouble for
    various other commands too.  How do those commands deal with it?
    True, but I don't think I'd blindly swap gates without looking in the
    schematic to make sure there aren't any issues.  Once there, I'd probably
    do the gate swap there.  If it only worked in the board, I could live with
    it though.
    In the example that prompted this, I was doing component placement and
    realized routing would be simplified by swapping some opamps of a quad
    opamp chip around.  That's probably a pretty normal case for wanting to
    swap gates.  However, it never even occurred to me to try doing this in the
    board.  I didn't know it wouldn't work, but I wanted to see what exactly I
    was swapping in the schematic, and that's where I attempted to do the swap.
    Doing it in the board seems awkward, but, again, I could live with it.
    hierarchy
    I need to understand more about hierarchy and why that causes trouble
    before making any suggestions.  Please explain.
    Best Regards,
    Jorge Garcia
