EAGLE User Support (English) ERC warnings
  • Views 887 views
ERC warnings
Why is it that the ERC tool generates warnings for POWER pins that are
connected to SUPPLY pins?
I know I can approve them but I still find it odd since in my opinion
device's POWER pins are precisely intended to be connected to SUPPLY pins
but apparently Eagle has a different opinion in this respect.
Robert
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • lbrer
    lbrer over 9 years ago
    ..my peers in company suggest me to use a good alternative: "IN" Pins for normally-PWR-Pins.
    There no "Forgotten" and no Warnings about the different names.
    regards hans
    Am 21.11.2016 um 13:51 schrieb Morten Leikvoll:
    On 21.11.2016 11:04, Joern Paschedag wrote:
    Am 21.11.2016 um 10:17 schrieb Morten Leikvoll:
    SNIP
    The other problem is that DRC does not check if you actually have a
    supply for your design. The single pin supply symbols only act as a poor
    page connector with implicit netname. This means it is easy to forget
    that you may need a regulator or power input for the supply symbols
    used. The DRC will not warn you about this.
    IMHO a very important point you have raised that should be taken care of.
    So far I have been lucky image
    I have been lucky too, but I did once end up with a regulator that was
    not in use image So maybe that could be part of the check.
    But I have started to make output pins of any regulator or similar
    device have "sup" direction on their output pins. This helps me
    slightly, but I do get a lot of the op warning messages. I prefer those
    messages over no warnings tho.
    Same thoughts here with me image
    Joern Paschedag
    SNIP
    SNIP
    Joern Paschedag
    One of the problems with the supply pin is that it explicitly defines
    the name it wants on the net connected. The problem this causes on multi
    rail power designs have been discussed in several threads.
    are connected to SUPPLY pins?
    opinion device's POWER pins are precisely intended to be connected to
    SUPPLY pins but apparently Eagle has a different opinion in this
    respect.
    Basically, you're right - but ERC does not complain about this, but
    about the different net names.
    A supply pin implicitly forces the attached nets name to that of the
    symbol (say GND, VCC, +24V etc.). A power pin implicitly connects to a
    net that matches its name, so it "wants" to be connected to this
    particular net name.
    If you connect a power pin with the name VCC to a supply net with the
    name +5V (for example), ERC complains about this. This has always been
    that way, and is boring from the day when these pin types and ERC were
    introduced - particularly when you're mixing different device types
    (analog, digital, several voltage rails) in a design.
    To be fair, there's no clean and easy way around this, unless EAGLE
    would simply ignore the names of power pins - but then, you can as well
    declare them as "passive" in the symbol... (That's what I do in symbols
    that will be used at very different supply names.)
    So at the end, it's fine that you can just "approve" these warnings. image
    Tilmann
