EAGLE User Support (English) How to find current shee t in ULP?
  • Views 965 views
I finally decided to write ULPs to go backwards and forwards one sheet in
the schematic editor, so that I could tie these to shortcut keys.
I looked at the ULP help again (version 7.7), and it appears the only
system state accessible to a ULP are the top level schematic, board, and
library structures, and then anything contained in them.  I looked over the
schematic structure again, but there appears to be no current state in
there, like the current schematic sheet.
How do I determine the current schematic sheet from a ULP?
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • gpsmikey
    gpsmikey over 9 years ago
    One place that lots of documentation falls down is providing links to
    common mistakes in searching for something.  For example "wire" who would
    think you don't use "wire" to connect things up in a schematic.  I ran into
    the same sort of thing the other day at Rockler Woodworking when I was
    looking for some knobs.  The knobs they listed in the index were for
    drawers etc, not what I was looking for - turns out they were listed under
    "jigs" in the index.  Put a quick link in the index that says "knobs - see
    also jigs" for example.  Same thing for "wire - see net".  You can find
    anything with Google in less than a second ... after you spend 3 days
    finding what the correct search term is !!
    warrenbrayshaw wrote on Fri, 02 December 2016 14:29
    I find the HELP very good when writing ULPs.
    Yes, the information is generally there.  Sometimes searches work, as you
    show.  Other times, you don't know what to ask, or a likely keyword is so
    generic that it get so many hits to be useless.
    The real problem is not the documentation that is there.  It serves the
    reference purpose when you know what you want to do, just need to look up
    some details.
    The problem is lack of any introductory or overview documentation.  The 10
    page Introduction to ULPs and How to Use Them is missing.  That goes for
    every other general Eagle capability.  This is not the same as reading the
    existing help.  Diving into details without the larger context is no way to
    learn, and all the details are clutter that detract from learning the
    higher level concepts.  Once you have those concepts, you are ready to ask
    specific question about details of commands.  The existing help does work
    for that, but not to get you to that level.
    In any case, once I found the schematic built-in command, writing the ULP
    was easy.  I know these already exist, but as a exercise to learn and
    verify that I understood things correctly, I wrote my own.  I also comment
    my ULPs, unlike most other people apparently.  Here is my ULP to advance to
    the next schematic sheet:
    #usage "
    h1. Go to next schematic sheet
    \n"
    int oldsheet;                     //1-N number of the current sheet
    int lastsheet;                    //number of last existing schematic
    sheet
    string cmd;                       //command to execute on exit
    //   Start of main program.
      sheet (sh) {                    //open the current sheet
        oldsheet = sh.number;         //get the 1-N number of the current
    sheet
      lastsheet = 0;                  //init last sheet number to invalid
      schematic (sch) {               //open the whole schematic
        sch.sheets(sh) {              //loop thru the sheets of the schematic
          lastsheet = max(lastsheet, sh.number); //save largest sheet number
      if (oldsheet < lastsheet)
        {                             //there is a sheet to advance to
          sprintf (cmd, "edit .s%d;\n", oldsheet + 1);
          exit (cmd);
        else {                        //already at last sheet
          exit (EXIT_SUCCESS);        //do nothing
    I tied these ULPs to hot keys in the schematic section of the eagle.scr
    file, and it works great.
    One disappointment was that actions can only be assigned to function,
    letter, numbers, and backspace keys.  I really wanted to assign these ULPs
    to the left and right arrows.  Those keys aren't otherwise used in Eagle,
    and that would make going thru pages forwards and backwards just like a PDF
    file with Acrobat Reader.
    Is there really a good reason Eagle couldn't allow assignment to the arrow
    keys and other special keys?  If not, that would be a nice feature to add.
    I suppose that should be the topic of another thread.
    On 3/12/2016 3:41 a.m., Olin Lathrop wrote:
    rk wrote on Fri, 02 December 2016 08:01
    However, the ULP you're trying to write already ship with EAGLE, look
    for "editnext-sheet.ulp" and "editprev-sheet.ulp".
    Thanks.  I looked at one of those as a example.  The trick is the "sheet"
    built-in statement.
    If you look at the help page USER LANGUAGE > OBJECT TYPES, it implies the
    only data structure-opening statements are LIBRARY, SCHEMATIC, and BOARD.
    I did find SHEET listed as one of the built-in statements later on.
    Eagle's help system strikes once again.  It is good for reference if you
    know what to look up, but not so good at helping you find things that you
    don't know about yet.  Argh.  I really hope AutoDesk does something about
    this.  Personally, I'd much rather they spend time on making the
    documentation usable for the introductory purpose too, not just for
    reference, than messing with the UI.
    I really do try to RTFM, but the M has to do its part by making the
    information findable for other than looking up details within a known
    context.
    The key is for one to choose the correct keyword to search on.
    Don't expect it to work well with "How do I do....?" It's not that style
    of tool.
    Identify the one word that should be within the explanation.
    Sometimes you need to have a second word choice to approach from a
    second angle.
    Sometimes you don't know how the functionality is described so knowing
    the best keyword is harder to know but that shows the need to have read
    the manual at least once.
    So the sheet example is a good example as you know you subject is sheets.
    I always remove make the search singular so search for sheet and not sheets
    If you key the word sheet, all pages containing the keyword are returned
    in bold.
    The area of interest is to do with 'User Language' so click on that and
    expand the tree , looking for bold type.
    There can be a lot of reading under 'Object Types' so my approach is
    always to get rid of the remaining scraps first. As with Olins's case,
    that is where the seed of the answer lay. This often the case as many
    powerful commands are outliers from the commands within the Object types.
    At other times I have used multiple words that I feel would be together
    in the explanation. 'sheet context' goes exactly to Olin's answer as its
    the only place with the word combination, but once you get there it's
    not obvious that it would be the answer to the question. In this case
    you need to recall that once the current sheet context is instantiated
    you will be able to read its number.
    So, while many of the help explanations have examples that clarify and
    educate, there are others that need another paragraph to enlighten the
    reader about what they have just read so they reach that " Oh! I see"
    moment.
    My view regarding documentation is one of education and to focus
    elsewhere, away from the app with a repository of mini-tutorials that
    explain the product and address questions, no matter where you are in
    the Eagle leaning process. Possibly along the lines of the W3schools
    site. (http://www.w3schools.com/)
    The goal should be for the forum to go very quiet and only solutions not
    available from this source to be raised.
    Warren
    built-in statement.
    context.
    Am 02.12.2016 um 13:54 schrieb Olin Lathrop:
    if(sheet) sheet(S)
        string txt;
        sprintf(txt, "Current sheet: %d", S.number);
        dlgMessageBox(txt);
    Rene
