EAGLE User Support (English) Diff class clearance
  • Views 1273 views
Are there any plans to split the diff routing clearance from the diff
spacing/gap? When you route diff signals now, the class clearance gets
used for spacing/gap too.
A typical example
spacing/gap (air between diff pair):0.1mm
track width:0.1mm
wanted clearance (to neighbour tracks): usually a few multiples of the
track width.
This forces me to change all clearances during DRC, and back again when
I want to route.
Of course there are more issues with diff routing, but lets do one step
at a time.
  • Joop14
    Joop14 over 9 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Thu, 08 December 2016 09:38
    On 07.12.2016 22:13, Joop wrote:
    You can set that in the netclass editor. Click on the ">>" button
    to open
    the netclass matrix editor where
    you can set the clearance in respect to other netclasses.
    I think you misunderstood. The clearance in the netclasses does both
    work as gap (for diff pairs) AND clearance to other classes. They need
    to be split.
    You are right. My mistake.
    Let's hope they give this priority over implementing online/webbased
    services for hobbyists...
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    autodeskguest over 9 years ago in reply to Joop14
    You can set that in the netclass editor. Click on the ">>" button to open
    to be split.
    What annoys me is that within a class, you can't set the clearance and
    trackwidth depending to the layer.
    The impedance of a track depends on the distance to a groundlayer and,
    depending to the board buildup,
    the distance between the different layers varies.
    So, it would be very convenient if, during routing of a differential pair
    (USB, LVDS), when changing layer,
    the width and clearance changes automatically in order to maintain the
    correct impedance.
    I agree this is also something to improve. For now I have made a script
    to change widths of a certain class on certain layers based on a stackup
    agreed upon with the manufacturer, but it would be nice if the width
    (and diff gap) were automatically changed when a stackup was changed.
    The DRC stackup definition is basically just missing the substrate
    dielectric (Er) constant fields to calculate this.
  • Joop14
    correct impedance.
