EAGLE User Support (English) change the title of a schematic in eagle
  • Views 2034 views
riverrock
riverrock over 9 years ago
How do I change the title of a schematic in eagle?
  • geralds
    geralds over 9 years ago in reply to rachaelp
    Yes, this is an alternative.
    Best Regards
    Gerald
  • rachaelp
    rachaelp over 9 years ago in reply to geralds
    As an alternative to this if, like me, you think having the filename the same as your schematic title in a frame is less than ideal, you can create your own frame and use global attributes to populate information such as the schematic's title.
    Edit->Global Attributes...
    Click "New"
    Give your new attribute a name e.g. TITLE and a value e.g. My Schematic Title
    Then place some text where you would like the TITLE attribute to be in the frame by using >TITLE as the contents of the text string. When placed this is filled with "My Schematic Title".
    Best Regards,
    Rachael
  • geralds
    You can rename the files in the panel.
    -> close the sch and brd files, then rename this files (klick the right mouse button).
    The file name is the title in the schematic frame.
    Gerald
