EAGLE User Support (English) Eagle V8 64 bit only?
  • Subscribers 189 subscribers
  • Views 1115 views
I cannot find any 32bit Windows version anymore on the Autodesk page. Is
that also part of the new strategy?
It could also be some auto-selection because I tried download with a
64bit OS and the user agent may be evaluated.
And no I don't want to be asked why I want to use 32bit SW on an 64bit
OS. I just want to know will/does it exist?
Markus
  • rachaelp
    rachaelp over 8 years ago in reply to jimmylatio
    jimmylatio  wrote:
    Yes, we need 32 bit Eagle version 8 & above, because our machine Windows OS all are in 32 bits, appreciated if can look into it, thanks in advance.
    Regards, Jimmy Lee
    We are 18 months on from when this thread was last active and nothing has changed in this regard. Autodesk EAGLE is available for 64-bit operating systems only. If you want to raise this with Autodesk you would be better to go onto their EAGLE forum and ask the question on there as their support team and developers are active on that forum. You can find the official Autodesk EAGLE forum here: https://forums.autodesk.com/t5/eagle-forum/bd-p/3500
    If you are truly stuck on 32-bit windows, how about dual booting to 64-bit Linux to run EAGLE? I know it's not ideal to be dual booting but if you are stuck and really need to run EAGLE on your current machine (assuming it's modern enough to run a 64-bit OS) then that might get you going.
    Best Regards,
    Rachael
  • jimmylatio
    jimmylatio over 8 years ago in reply to autodeskguest
    Regards, Jimmy Lee
    I hope you're doing well. It was determined that since the overwhelming
    majority of our downloads were for 64-bit that we would only support
    64-bit architectures across Mac, Linux and Windows.
    If enough people ask for 32-bit, we are willing to look into this.
    Don't worry I won't ask why you want to run 32-bit software on a 64-bit
    machine. I have to do that with other tools before so no worries.
    Thanks a lot. Quick and precise reply as always Jorge, appreciate it.
    I really hope this whole thing turns out well for all affected people.
    Markus
    Markus
    Hello Markus,
    Best Regards,
    Jorge Garcia
