EAGLE User Support (English) Placing vias off grid
  • Subscribers 187 subscribers
  • Views 649 views
quite often it happens to place components off grid. The common case is
when you have several IC with different pin pitches.
One issue I have is to place vias on tracks off grid.
Simple example:
1. place a component with pins off grid
2. route tracks (say horizontally) from those pins straight out (i.e.
you will have parallel tracks spaced by the IC pitch)
3. now you want to connect a wire (vertically) to one of the tracks,
using a via
Best case: the vertical track is on grid. So only the Y position of the
via is off grid.
Worst case: also the vertical track is off grid. Both X and Y
coordinates of the via will be off grid.
The only way I found is:
1. start routing from the off grid track (in the worst case it doesn't
matter which of course), in this example I assume the horizontal one
2. set the wire bend settings to the right corner
3. change layer so the via is placed automatically
4. connect to the other track
5. with the info tool copy the X coordinate of the vertical track
6. close the info tool, and open it again on the via
7. past the value to the X coordinate
Now you have the via properly aligned with the vertical track.
It takes a long time if you have to route dozens of tracks!
And if both tracks are off grid you have to repeat the process twice, or
at least you have to move around them to go on grid.
I never wrote an ulp so before start learning I would ask if it is
possible to do the following.
I'm thinking about an alignment aid. The flow would be this:
1. route the new track regardless the grid
2. right click on each end and select "align to"
3. specify the reference (if it's a track the correct axis is inferred
automatically - the one that doesn't change, it it's an object or a via
it could ask for X or Y)
    Il 26/02/2017 03:34, warrenbrayshaw ha scritto:
    Most people use the freehand approach to this challenge, eyeballing it
    into place.
    Set the alternate grid to finest. Then with the ALT key depressed, move
    the via with its attached routing segments to where you need them.
    It could work, but it's not so easy to put a via at the exact
    coordinates by eye. I know myself: I will inspect the position to be sure image
    On the other hand EAGLE is a CAD! Hence I would expect some facilities
    to position and align objects.
    into place.
    On 26/02/2017 3:10 a.m., Marco Trapanese wrote:
    Simple example:
    using a via
    via is off grid.
    Now you have the via properly aligned with the vertical track................
    into place.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    Another way would be to allow mouse snapping to tracks, not only grid
    and pads. But this would require a change in EAGLE so didn't consider it.
    Il 25/02/2017 15:10, Marco Trapanese ha scritto:
    Simple example:
    using a via
    via is off grid.
