EAGLE User Support (English) Unable to name polygon
  • Subscribers 187 subscribers
  • Views 666 views
I'm running Eagle 4.16r2.  I've created a polygon on the top layer.  It's
the ground pad for the tab of a TO-263 package, so I want to name it GND to
connect it to my GND signal, plus turn on related features like cream etc.
When I click on the NAME button and then on the polygon, however, my system
just beeps and won't let me name it (though it lets me name the pads for
the pins).  What am I doing wrong?
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    Thanks for the tips, Warren.  I thought of making a big pad, but I was
    trying to adhere to the datasheet which specifies a T shaped pad; a
    rectangular one would be ... imperfect.  image  As for the Linear library, had
    I known there was a TO-263 package in there I would have used it.  Now I
    need to decide whether it's easier to plug that one into my design or just
    add a big rectangular pad to it.
    Karl
    etc. When I click on the NAME button and then on the polygon, however,
    my system
    Hi Karl
    it was not until after v4 that polygons over pads to make custom pads
    arrived.
    Why don't you just make a large SMD pad for that tab pad.
    The Linear library has a TO-263 package 3 pin you could use or adapt.
    HTH
      Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    In case it wasn't clear, this is happening in the part editor, so the
    polygon will be part of the part.  I'm not doing it in the board layout.
