EAGLE User Support (English) Consistency error. ERC check points to a non-existing part
  • Replies 8 replies
  • Views 1011 views
Plecto
Plecto over 9 years ago
"Different connection on K102 pin P and pad COM (none/N$48) it says, it's one among many. K102 is not part neither on the schematic nor on the board, If I try to search for it I find nothing. N$48 is on component K10 so where does K102 come from and how do I fix this?
    I think you have found a bug. I see you are using v8.0.1
    If Jorge is reading this, please check the files the OP posted.
    Hi Warren,
    I hope you're doing well. You are indeed correct this is definitely a
    bug and one that has apparently been around for a while. I'll write a
    bug report so that this can be resolved.
    Thanks for everything you did to help this user out.
    Let me know if there's anything I can do for you.
    Best Regards,
    Jorge Garcia
    We have a new forum here <http://forums.autodesk.com>
    Hi Warren,
    Best Regards,
    Jorge Garcia
    Hi Warren,
    Best Regards,
    Jorge Garcia
  • Plecto
    Plecto over 9 years ago in reply to autodeskguest
    Wow, I'm really grateful for that image Thank you
    Am 12.03.2017 um 09:34 schrieb warrenbrayshaw:
    https://www.element14.com/community/message/218161
    Hi
    Thanks for posting the Sch and Brd files.
    I checked out your files using v7.7  and I see K102 as well in the error
    list and yet there is no K102 nor in the XML
    That K102 appears to be a poorly described gate 2 of K10
    There are many example there in the files you posted
    As is normally the case with lost forward/backward annotation (Lost
    consistency) you likely made changes in the schematic without having the
    board open at that time.  Always have both open as you perform edits.
    One problem is the COM pads of the relays on the board. I feel at one
    time the schematic had nets and then they were removed with the board
    not open. The pads have contact references on them but that signal goes
    nowhere else.
    The simplest fix was to connect all the NO pins and that X5-1 pin with
    N$97 and then with the board open, delete all the N$97 net connections
    and board then dropped the reference to that net on all those pins.
    Hence all those errors disappeared.
    The other pins all had different nets so to do the job quickly I edited
    the XML for the board. They stood out because they were signals with a
    single Contact Ref to a COM pad.
    Long story short, I have corrected the inconsistencies in your BRD file
    so you should be good to go.
    You will likely have to pick it up from
    http://www.eaglecentral.ca/index.php/f/36/82ebb8ae529a7d06eea5d20bcc1b1ba4/
    as E14 cannot pick up attachments from the newsgroup forum that E14
    piggy backs onto.
    All the best
    Warren
    Yes there is a fault in the library with different names for the Contact
    pads in symbol and device.
    Joern Paschedag
    Hi
    nowhere else.
    piggy backs onto.
    All the best
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    Multiplekser for testing av ultralydprober.zip
  • Plecto
    Alright, I apologize. Here are the board and schematic files.
    2477.Multiplekser for testing av ultralydprober.zip
    There's a heap of information /answers to questions you would need to
    provide to narrow down how this happened. The fix could well be that you
    will need to edit the XML of the sch and brd files.
    Your best move is to upload the files so that we can see what has
    happened to them.
    Zip them if they are to big to post and you may need to zip them
    separately and post them in two separate postings.
    Warren
    Thunderbird!
    support forums.
