EAGLE User Support (English) Bounds
  • Subscribers 187 subscribers
  • Views 715 views
Bounds
Hi, Eagle keeps insisting that when I goto move a component it is out of
bounds. No matter when I place it I get that ******* beep. How do I get
Eagle to show me where the current bounds are?
    Hi
    You can have Eagle show you your design boundaries but you need to set
    that up for yourself.
    The boundaries depend on the version and edition of eagle you have.
    Prior to version 8 they were fixed width and height but now with v8 you
    are restricted to an area and you set the desired height and width in
    the settings, staying under the area restriction.
    I'll attach a library to give you an idea for an approach.
    This library only has one package, as an example. It is for 100mm wide x
    80mm high. Just ADD that package to the board at the origin of the board
    editor and that's the valid area for the free versions prior to v8. It's
    drawn on the un-routed layer as there is only a low chance that that
    layer would be included in any gerber or documentation files.
    As a practice you could make the next most common size 160mm x 100mm
    I expect for v8 you will need to set the desired size prior to
    commencing the board and build a package guide for that size.
    You can also turn off the beep in the settings.
    Options > Set >  Misc > Beep
    HTH
    Warren
    Thank You I will give that a try going forward.
    Part of my issue turned out to be that I was still using freeware
    license even though I thought I activated my V8 std license.
    Glenn
    Hi
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    Try placing things above and to the right of the origin mark.  There are a
    couple different versions of EAGLE with different size limitations, so
    depending upon which version you have, the bounds will be different.  I
    always start by drawing a rectangle around the size that I want.  That may
    help you...
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
