EAGLE User Support (English) Eagle autorouter not working
  • Replies 10 replies
  • Subscribers 184 subscribers
  • Views 3250 views
  • working
  • autorouter
  • not
Autorouter was working ok and I created a simple circuit layout but after moving some components around, autoroute has stopped responding, i says its 100% complete but it doesn't move or route any of the wire tracks. Its looking a real mess with tracks all over the place. Has anyone had similar problems or know how I can get autoroute back to a working state?
thanks in advance
    autodeskguest over 10 years ago +1
    On 01/11/15 00:28, steven robinson wrote: Autorouter was working ok and I created a simple circuit layout but after moving some components around, autoroute has stopped responding, i says its 100% complete…
    working state?
    That's probably because, when you moved things around, you left the
    routed tracks all over the place! The autorouter will, for very good
    reasons, only act on UNROUTED airwires. So if you have made a mess and
    need some tracks re-routed, you must use RIPUP on them first.
    Former Member over 10 years ago in reply to autodeskguest
    Brilliant ! thank you image its all done. Ripup did the job
    Former Member over 10 years ago in reply to Former Member
    Any idea how do you deal with tracks present in the schematic that don't appear on the pcb layout? They aren't showing at all in PCB layout, not even as airwires
    autodeskguest over 10 years ago in reply to Former Member
    Am 03.11.2015 um 12:11 schrieb steven robinson:
    even as airwires
    http://www.element14.com/community/message/165840
    try "ERC" to check that board and schematic are consitant.
    Have you draw the "tracks" in the schematic with the "wire" or with the
    "net" command?
    The "net" is the right one.
    Are the nets connected to the pins of the symbols?
    Try to move the symbol; the net have to move with the symbol like
    a ribbon.
    HTH
    Werner
    Thanks Werner
    I had drawn with wires so I've changed to nets. Thats done the trick but how do I avoid wires crossing? I guess thats why I should use vias? Any pointer?
    Steve
    Am 03.11.2015 um 22:08 schrieb steven robinson:
    Thanks Werner
    pointer?
    Steve
    http://www.element14.com/community/message/165903
    the "wires" on the board or in the schematic?
    On board: there a differnt layers witch you can use (top/Bottem)
    If you use the "Route" command you can switch the layer with the
    mouse button.
    In schematic:
    If you cross two nets they arenot connected. If you want do this you
    have to use "junction".
    Please refer http://www.cadsoftusa.com/training-service/tutorials/
    for a manual that suites to your eagle-version.
    HTH
    Werner
    Thanks Werner
    That did help image I mean't the wires on the board, I used different layers as you said and it created its own vias. image
    Thanks for the help
    Steve
    so I'm ready to create my gerber files and I've noticed that the onboard audio pro micro thats a component in my project seems to be adding its drill holes to the final gerbers. Any ideas how I eliminate drill holes, pads, vias etc that are part of a component only?
    thanks
    Steve
    thanks
    Steve
    http://www.element14.com/community/message/166113
    Please - one subject per thread
    Forums have an etiquette
    Warren
    Sorry Warren, it was the same subject just re-worded.
    Steve
