EAGLE User Support (English) How to Unlock components from the command line (or script).
  • Replies 14 replies
  • Subscribers 183 subscribers
  • Views 4174 views
dukepro
dukepro over 8 years ago
Eagle 7.7.0
It's clear how one can lock the position of components from the command
line:
    Lock LED1 LED2 LED3;
But what is not clear is to how to unlock it.  Thus far, I have tried:
    Lock -LED1      # Unkown element: -
    Lock S LED1     # Unknown element: S
    Lock (S) LED1   # Invalid point: (S) LED1
    Lock (S LED1)   # Invalid point: (S LED1)
What I'd like to see is:
    Unlock LED1 LED2 LED3;
Ideas? Suggestions?
Thanks for the help.
    - Chuck
5140.att1.html.zip
  • WarrenBrayshaw
    WarrenBrayshaw over 7 years ago +2
    Hi There is another way. If the following is in the command line LOCK (S@) and then you position the mouse over the locked element and hit enter, the element is unlocked. @ means, 'at the current cursor…
  • rachaelp
    rachaelp over 7 years ago in reply to dukepro +2
    Hi Chuck, I'm not sure why GitLab isn't working for you, it seems to be fine for me. I can send you a copy of the repository, no problem. Do you still have the same email address? If so I can send you…
    autodeskguest over 7 years ago in reply to autodeskguest +1
    On 26.07.2018 13:40, Morten Leikvoll wrote: On 26.07.2018 13:38, Morten Leikvoll wrote: On 04.07.2017 00:13, Chuck Huber wrote: Eagle 7.7.0 It's clear how one can lock the position of components from the…
    Lorenz wrote:
    something like the following would be my first try
    beware: not tested at all!
    >     board(BRD) {
    >       clrgroup(BRD);
    >     BRD.elements(ELM) {
    >         if (ELM.name == argv[1]) {
    >           setgroup(ELM);
    >           exit("lock (>0 0);");
    missing the 'S' in the lock command invocation, and handles to first
    parameter only.
    This is the improved and tested version:
         board(BRD) {
           clrgroup(BRD);
           BRD.elements(ELM) {
             int i;
             for (i = 1; i <= argc; i++) {
               if (ELM.name == toupper(argv[i])) {
                 setgroup(ELM);
           exit("lock (>S0 0);");
    Lorenz
  • dukepro
    dukepro over 7 years ago in reply to rachaelp
    Good morning, Rachael,
    It's interesting that this thread has come back to life after over a
    year.  I still haven't found a native way of unlocking, and have to
    resort to writing a ULP.  I figured that your code would be a good place
    to start, but it turns out that gitlab.com isn't taking requests.
    Do you have another stash for your utilities?
        - Chuck
    On 07/04/2017 09:46 AM, Rachael wrote:
    You can find the documentation for my EAGLE ULP library here:
    https://www.element14.com/community/people/rachaelp/blog/2017/03/03/eagle-ulp-utilities-library
    And the GIT repository is here:
    https://gitlab.com/rachaelp/eagle-utils
    Best Regards,
    Rachael
  • dukepro
    dukepro over 7 years ago in reply to dukepro
    Rachael,
    Actually, I just found it on another machine.  Version 0.1 alpha 1
    (07-Jul-2017 09:04)
        - Chuck
        - Chuck
    Best Regards,
    Rachael
  • rachaelp
    Hi Chuck,
    I can send you a copy of the repository, no problem. Do you still have the same email address? If so I can send you a copy to there image
    Best Regards,
    Rachael
