EAGLE User Support (English) How to Unlock components from the command line (or script).
  • Replies 14 replies
  • Subscribers 191 subscribers
  • Views 4816 views
dukepro
dukepro over 9 years ago
Eagle 7.7.0
It's clear how one can lock the position of components from the command
line:
    Lock LED1 LED2 LED3;
But what is not clear is to how to unlock it.  Thus far, I have tried:
    Lock -LED1      # Unkown element: -
    Lock S LED1     # Unknown element: S
    Lock (S) LED1   # Invalid point: (S) LED1
    Lock (S LED1)   # Invalid point: (S LED1)
What I'd like to see is:
    Unlock LED1 LED2 LED3;
Ideas? Suggestions?
Thanks for the help.
    - Chuck
5140.att1.html.zip
  • rachaelp
    rachaelp over 8 years ago in reply to dukepro
    Hi Chuck,
    I'm not sure why GitLab isn't working for you, it seems to be fine for me.
    I can send you a copy of the repository, no problem. Do you still have the same email address? If so I can send you a copy to there image
    Best Regards,
    Rachael
  • dukepro
    dukepro over 8 years ago in reply to dukepro
    Rachael,
    Actually, I just found it on another machine.  Version 0.1 alpha 1
    (07-Jul-2017 09:04)
        - Chuck
    On 07/30/2018 08:44 AM, Chuck Huber wrote:
    Good morning, Rachael,
    It's interesting that this thread has come back to life after over a
    year.  I still haven't found a native way of unlocking, and have to
    resort to writing a ULP.  I figured that your code would be a good place
    to start, but it turns out that gitlab.com isn't taking requests.
    Do you have another stash for your utilities?
        - Chuck
    On 07/04/2017 09:46 AM, Rachael wrote:
    You can find the documentation for my EAGLE ULP library here:
    https://www.element14.com/community/people/rachaelp/blog/2017/03/03/eagle-ulp-utilities-library
    And the GIT repository is here:
    https://gitlab.com/rachaelp/eagle-utils
    Best Regards,
    Rachael
  • dukepro
    dukepro over 8 years ago in reply to rachaelp
        - Chuck
    Best Regards,
    Rachael
    autodeskguest over 8 years ago in reply to autodeskguest
    Lorenz wrote:
    something like the following would be my first try
    beware: not tested at all!
    >     board(BRD) {
    >       clrgroup(BRD);
    >     BRD.elements(ELM) {
    >         if (ELM.name == argv[1]) {
    >           setgroup(ELM);
    >           exit("lock (>0 0);");
    missing the 'S' in the lock command invocation, and handles to first
    parameter only.
    This is the improved and tested version:
         board(BRD) {
           clrgroup(BRD);
           BRD.elements(ELM) {
             int i;
             for (i = 1; i <= argc; i++) {
               if (ELM.name == toupper(argv[i])) {
                 setgroup(ELM);
           exit("lock (>S0 0);");
    Lorenz
    On 26.07.2018 13:40, Morten Leikvoll wrote:
    On 26.07.2018 13:38, Morten Leikvoll wrote:
    On 04.07.2017 00:13, Chuck Huber wrote:
    Eagle 7.7.0
    command line:
    (stuff deleted)
    I dont know if it an sw accident, and it is probably just a curiosity
    and of no practical use, but this works on 7.7.0:
    Type
         Lock <refdes>
    then immediately follow up with
         (S@)
    ...and it gets unlocked! But the mouse pointer needs to be within the
    window for it to work.. Maybe there are other side effects that can be
    explored..
    Having just said that, here seems to be the solution to unlock!:
    "lock <refdes> (S@);"
    Damn, I was too quick.. My mouse pointer was too close to the device I
    was playing with. Both my suggestions fail if the pointer is closer to a
    different device.. Sorry for the alarm image
    Eagle 7.7.0
    command line:
    (stuff deleted)
    Type
        Lock <refdes>
        (S@)
    explored..
    "lock  (S@);"
    Eagle 7.7.0
    line:
    (stuff deleted)
    Type
         Lock
         (S@)
    explored..
    late but ...
    Chuck Huber wrote:
    Eagle 7.7.0
    line:
    Ideas? Suggestions?
    if you are ok with something like "run unlock LED1 ..." you could
    write an ULP that groups the given parts using the setgroup() function
    and then issues an "lock (>0 0)" on exit.
         board(BRD) {
           clrgroup(BRD);
         BRD.elements(ELM) {
               setgroup(ELM);
    Lorenz
  • WarrenBrayshaw
    WarrenBrayshaw over 8 years ago
    Hi
    There is another way.
    If the following is in the command line
    LOCK (S@)
    and then you position the mouse over the locked element and hit enter, the element is unlocked.
    @ means, 'at the current cursor position'.
    That's a command line option but not much different to the mouse right click and selecting 'Unlock'
    If you then assign a key combination to cause the  LOCK (S@) , then the action to unlock an element becomes:
    Position mouse over the locked element and then depress the key combination that runs LOCK (S@)
    Warren
  • rachaelp
    rachaelp over 8 years ago in reply to shekharkarmarkar
    shekharkarmarkar  wrote:
    There is simple way to unlock components. Select component > Right click and go to properties. Uncheck lock. That is all.
    The question was about unlocking components form the command line or a script, i.e. when you are automating something. Of course you can do it from the context menu, or the properties but that doesn't help with automation.
    That is all image
