EAGLE User Support (English) grounded hole?
  • Subscribers 186 subscribers
  • Views 2140 views
grounded hole?
Normally, I want my mounting holes isolated from the circuit. However, in a
board I'm working on, I want one hole to connect to the ground plane
(polygon). I made a large via with the drill size the same as the mounting
hole drills. And I put a large circle of tStop around the via for the screw
head. Is this the correct way to do this?
    It doesn't sound wrong, per-se, but have you looked at the "mount pad"
    devices in the "holes" library that comes with Eagle?
    autodeskguest over 10 years ago in reply to autodeskguest
    Rob Pearce wrote on Mon, 09 November 2015 13:21
    Rob - I forgot all about those. Thanks.
    Former Member over 10 years ago in reply to autodeskguest
    You can create a grounded mounting hole as a DEVICE in your EAGLE library.  Use a pad with desired drill and diameter in the PACKAGE section, and then create a ground (or chassis) symbol for it in the SYMBOL section.  Connect pad and pin together and give it a name like "GP", for example.
