EAGLE User Support (English) Peltier Cooling Module Data sheet understanding
  • Replies 8 replies
  • Subscribers 186 subscribers
  • Views 2875 views
I am working on a project which envolves the implementation of Peltier
modules. I am a mechanical engineering student. Currently, I am dealing
with a Peltier cooling Module whose data sheet is shown below in the
link from Farnell UK. We have Peltier cooling modules in the project
which are supposed to cool down some flowing air. This is the first time
I encounter Peltier modules.
http://www.farnell.com/datasheets/1693164.pdf
(https://mail.yandex.com/re.jsx?h=a,ggFabqW2FW_fTrpozMU2CQ&l=aHR0cDovL3d3dy5mYXJuZWxsLmNvbS9kYXRhc2hlZXRzLzE2OTMxNjQucGRm)
1-
I would like to ask about any good books available on the
Thermo-electric effect, and more particularly Peltier modules, the
physics behind them, mathematical models of them and their
implementation.
2-
Also I would like to ask about the performance graph of the Peltier
module (see the link below). According to what I understood from the
explanation available on the Internet, the Pc notation on the graph
refers to the cooling power. Is it the rate at which heat energy is
absorbed on the cold side ??
3-
There is a heat little heat exchanger which consists of a heat sink,
which holes filled in it and pipes are connected to flow water through
the heat sink to increase the convective heat loss and prevent any
overheat. While Tc the temperature on the cold side, can Th be
considered as the ambient temperature ?
http://oi57.tinypic.com/34hj2m8.jpg
(https://mail.yandex.com/re.jsx?h=a,Ve6XfGxq9DeW05E65tYxrQ&l=aHR0cDovL29pNTcudGlueXBpYy5jb20vMzRoajJtOC5qcGc)
4-
On the performance graph, the "Th" at which the data in the graphs were
collected is noted to be 25 C. Does this mean that I can refer to the
graphs only in case that that the temperature on the hot side at that
temperature ??
This because I found some sources on the Internet claiming at an offset
of ±10 C, with a slight margin of error.
5-
The other thing I need to understand is that if my understanding of the
cooling power "Pc", and if the temperature on the hot side "Th" remains
constant as shown on the graph, for a given value of current as shown
with the ascending lines on the right side in the lower section of the
graph, why would the cooling power (the power absrobed on the cold side)
fall if the temperature on the cold side falls as well. If my
understanding of the cooling power is correct, then wouldn't the
temperature of the cold side drop as more power "Pc" is absrobed ??
6-
In the lower section of the graph, if I choose two different
intersection points on the straight line of the current value 4.8 Amp,
when at "Tc = -20 C & Pc = 40 W" and when at "Tc = -5 C & Pc = 60 W",
the corresponding temperature differential "dT" between "Tc" and "Th" is
"45 C" and "30 C" in relation to the "Th" shown on the graph
respectively. Thus, on the upper section of the graph, on the current
line of 4.8 Amp, the intersection of the line with "dT= 45 C" & "dT= 30
C", yields voltage values of "V= 24.5 volts" & "V=23.5 volts"
respectively. How can the same amount of current, and slight difference
in voltage create a substantial difference in the temperature on the
cold side ??
7-
How can I start with the implementation of the Peltier module, as I need
a starting point. According to what I understood, I need to specify the
temperatures I need on both sides of the module, with the cooling power
(the power to be absorbed on the cold side, if my understanding of the
cooling power shown on the graph is correct), so that I can specify the
electric current value I need. Based on the temperature differetial
between the hot and the cold side, and the value of the current, I can
then determine the value of voltage I need to supply to the Peltier
module, so that it generates the difference in temperature I need. Am I
on the right track, and is there any piece of advise that I can make use
of ??
Sorry for the very long thread.
Thanks in Advance
Regards
http://www.element14.com/community/message/163918
    Hi Banshee,
    I will ask  to move your question to a better group.
    http://www.element14.com/community/message/166186
    autodeskguest over 10 years ago in reply to autodeskguest
    Dear Mr. Paul
    Thanks very much for your help and reply, and allow me to apologise for
    my very late reply. Please check my reply to Mr. Michael Kellett, where
    I explained my case in more detail.
    Regards
    http://www.element14.com/community/message/166211
    Dear Mr. @Michael Kelltett
    I am sorry for the link not workig. The link works fine with me. Anyway,
    it contains the performance graph of Peltier Module I have, and the same
    graph is shown in the first link, which is the datasheet from the
    manufacturer. I uploaded both as attachments.
    The link of @Paul Ellison presented some similar explanation I found
    online regarding the graph itself. However, it does not explain the
    reason behind the Peltier behavior. I have not had the greenlight from
    my supervisor to operate the last Peltier module we have, because I
    still do not know why for a given value of current, the temperature
    differential (dT) falls when the power of cooling (Qc) increases. I
    suppose when the Peltier module pumps more heat, the different in
    temperature between the Peltier junctions has to increase, as the cold
    side's temperature will drop with more heat drawn from the cooled
    object.
    An initial experiment that I have to conduct before implementing the
    Peltier module in the project is to cool an amount of water and
    determine the efficiency of the Peltier module, using an insulated
    container. Thus, I assume that for a given value of current, the higher
    the cooling power (heat drawn), the larger the difference will grow
    between the junctions, as the cold side of the Peltier will fall in
    temperature compared to the hot side.
    Plus, the datasheet of the Peltier module we have, you can notice that
    for a given amount of current (the straight lines in the lower section),
    the cooling power falls with the increase of the temperature gradient
    (the temperature of the cold side falls while the temperature of the hot
    side remains 25 C as indicated on the graph), and that's according to
    the voltage supplied with that amount of current, as shown in the upper
    section of the graph. nevertheless, I see that with a slight difference
    in voltage, a large difference in temperature gradient in generated,
    which is not very logical to me. Add to that, that I have no control
    over the current supplied, as the electronics guys in our project set up
    the power supply to be through PWM for all the parts of the project, and
    I have no much idea about that.
    Sorry again for the long post.
    Thanks for your reply
    Regards
    http://www.element14.com/community/message/166150
    Who can I contact (an admin or moderator) who may be capable of helping
    me to move this thread/discussion to the right section ?
    Regards
    http://www.element14.com/community/message/166148
    Dear Mr. Joern
    I am so sorry for this, mistake, I just did not notice that I was
    posting in the wrong place. I just clicked on the "Start a Discussion"
    button on the home page, as I found some difficulities surfing my way in
    the website.
    Sorry for the very late reply, as I have been very busy lately.
    Regards
    http://www.element14.com/community/message/166147
    Your link doesn't lead to a picture but to some website requiring
    clicking and who knows what else. If you insert your picture directly
    into your E14 post I'll be able to look at it.
    Did you get the information you need from the link Paul gave you or are
    you still stuck ?
    http://www.element14.com/community/message/163962
    This page may answer some of your questions:
    TEC / Peltier Element Design Guide | Compendium
    (http://www.meerstetter.ch/compendium/tec-peltier-element-design-guide)
    http://www.element14.com/community/message/163950
    Am 21.10.2015 um 22:24 schrieb Banshee For:
    1-
    implementation.
    2-
    3-
    4-
    temperature ??
    5-
    6-
    cold side ??
    7-
    of ??
    Thanks in Advance
    Regards
    This is certainly the wrong  forum place for your questions.
    This is the  eagle forum and here we discuss problems and possibilities
    about the  eagle CAD software.
    Joern Paschedag
