EAGLE User Support (English) Library for TSU104IPT?
  • Subscribers 187 subscribers
  • Views 428 views
  • eagle
  • library
  • tsu104ipt
brightnight
brightnight over 8 years ago
I'm looking to make my first real PCB with eagle and want to use the a"STMicroelectronics  TSU104IPTTSU104IPT op amp chip The spec sheet says the package is a
"14-TSSOP", however I couldn't find anything in my eagle library with the same footprint. I was going to make a schematic, then turn it into a PCB. Do I have to make my own package size for this to use or is there something existing I can download? Is this a common package? It doesn't have to be for this op -amp...just something that with the same footprint and number of pins. Thanks advance for your advice-just getting into it and there's a lot to learn so I apologize if there is something simple  I'm overlooking.
Spec sheet for the  TSU104IPTTSU104IPT
https://www.digikey.com/product-detail/en/stmicroelectronics/TSU104IPT/497-14090-1-ND/4499538
    autodeskguest over 8 years ago
    Am 20.12.2017 um 06:27 schrieb pete sampson:
    I'm looking to make my first real PCB with eagle and want to use the a "STMicroelectronics TSU104IPT" op amp chip. The spec sheet says the package is a
    Spec sheet for the TSU104IPT:
    https://www.element14.com/community/message/232535
    1. You either look for an Op-amp with the package you want, copy it into
    your own library, edit and name it.
    2. packages one can find in "ref-packages.lbr"
    3. Important is to create your own libraries, because if you change the
    eagle libraries all of your work will be lost on the next eagle update.
    Joern Paschedag
