EAGLE User Support (English) Producing boards with custom libraries
  • Views 510 views
zaaphod
zaaphod over 8 years ago
I have a board I am working on that uses custom libraries that I want to have professionally produced.  Can I just supply the Eagle board file (.BRD) or will I need to send the library as well?
  • rachaelp
    rachaelp over 8 years ago
    Hi James,
    You shouldn't need to send out any library files although it should be noted that the library footprints can be exported from the board file in if necessary. Depending on where you are getting your boards built you are more likely to have to generate Gerber files and assembly drawings using the CAM processor to send to the manufacturer than send the board.
    Best Regards,
    Rachael
