EAGLE User Support (English) BUG: enter doesn't work in control panel
  • Subscribers 187 subscribers
  • Views 751 views
I just installed version 7.5.0, and ran into a new bug.  I can navigate
thru the file tree view in the control panel as usual, but ENTER doesn't
work anymore to cause a file to be opened.  Apparently you have to double
click.
This is a rather blatant bug to slip thru.  It shows that your developers
use the mouse instead of the keyboard.  That's a preference, but everything
still needs to be checked using the keyboard as much as possible.
Personally, I prefer to type rather than click, because typing is so much
faster.  One of the great things about Eagle is that the underlying system
is command based, so that you can enter commands with the keyboard.
Between that and the flexible hot key system, you can really navigate and
control Eagle quickly with the keyboard.  The mouse only needs to be used
for inherently graphical interactions.
    autodeskguest over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Fri, 20 November 2015 12:10
    Just filed the bug report.
    Thanks for finding this one, I personally didn't know you could use the
    enter key in the Control Panel.
    I just installed version 7.6, and this seems to be fixed.  Thanks for
    taking care of this.
    That's pretty standard for all such expanded tree views in Windows.  It
    works in Windows Explorer, for example.  It seems some library routine does
    this tree view thing, because it works that way in most such programs.
    I just tried what Gerald said, which is to use SPACE.  I didn't know SPACE
    did that, but it does work.  That's a workaround for now, but my fingers
    are used to ENTER.
    click.
    Hi Olin,
    Best Regards,
    Jorge Garcia
  • geralds
    geralds over 10 years ago
    i also work with the 7.5.0 on windows 10 pro.
    In the panel you can also opening or closing the folders with the space button.
    And also with the space button you can opening the project files; e.g. sch and pcb.
    Yes the enter button doesn't work. This seems a bug.
    Of the other hand I think this would be good because the enter button is a little bit strong command, isn't it?
    regards
    Gerald
