EAGLE User Support (English) Plated Through Slots
  • Views 1059 views
dukepro
dukepro over 8 years ago
Good afternoon, all,
What is the best way to designate a slot to be plated through?
Essentially, I need an oval shaped hole that's plated through.
Eagle v7.7.0.
Ideas?
    - Chuck
  • dukepro
    dukepro over 8 years ago in reply to autodeskguest
    Eagle v7.7.0.
    Ideas?
         - Chuck
    Ive done this quite a few times (Eagle 7.7.0). It works best on
    library parts because then you can control each layer in the same go.
    Adding a milled slot directly on the board requires careful planned
    routing around and under it.
    In the package editor, I start with a pad somewhere at one corner/end
    of the slot. If you set the pad hole size to the mill width, you can
    get a better impression how much copper you need around the slot. Then
    I add the mill shape over the pin. In some cases a oblong pad may be
    the correct shape, but if not, I draw a polygon on each of the 16
    layers, even if Im only using just a few of them. Make sure the
    polygons generates a "rest edge" as large as the rest-ring of the pad.
    Always add stop and paste layers to polygon pads. You may disalbe the
    pad's stop and paste, but they should ideally merge with the one you
    draw.
    Remember to send the gerbers of the mill layer and write a doc how to
    use it.
    The manufacturer will most likely understand that milled patterns in
    the middle of all-layers copper island should be plated, but you
    better add it to the docs too.
    Note:If you embed the slots in polygons, the fill thermals maybe have
    some connection issues with polygon pads. Make sure they look ok, or
    disable thermals of the polygons. Also note the added heat required to
    solder these slots.
    Good morning, Morton and Paul,
    That's about what I was thinking as well.  I hadn't thought about
    putting a manual rest ring in on all layers, nor the mask.  The pad
    confirming the finished hole size is another good idea.  All good ideas.
    I agree with the problems of using the milling layer on the board.  It's
    very easy to overlook a trace crossing over it - I've don't it.  As
    such, I use the dimension layer for non-plated slots to allow the DRC to
    catch such errors.
    The copper around the slot and a note in the README should queue the
    board house to route the slot prior to plating, or at least to call me
    if they're left scratching their heads.
        - Chuck
  • dukepro
    Eagle v7.7.0.
    Ideas?
         - Chuck
    draw.
    use it.
    solder these slots.
    catch such errors.
        - Chuck
    autodeskguest over 8 years ago
    Eagle v7.7.0.
    Ideas?
        - Chuck
    Ive done this quite a few times (Eagle 7.7.0). It works best on library
    parts because then you can control each layer in the same go. Adding a
    milled slot directly on the board requires careful planned routing
    In the package editor, I start with a pad somewhere at one corner/end of
    the slot. If you set the pad hole size to the mill width, you can get a
    better impression how much copper you need around the slot. Then I add
    the mill shape over the pin. In some cases a oblong pad may be the
    correct shape, but if not, I draw a polygon on each of the 16 layers,
    even if Im only using just a few of them. Make sure the polygons
    generates a "rest edge" as large as the rest-ring of the pad. Always add
    stop and paste layers to polygon pads. You may disalbe the pad's stop
    and paste, but they should ideally merge with the one you draw.
    use it.
    The manufacturer will most likely understand that milled patterns in the
    middle of all-layers copper island should be plated, but you better add
    it to the docs too.
    solder these slots.
    Eagle v7.7.0.
    Ideas?
        - Chuck
    use it.
    it to the docs too.
    solder these slots.
    Eagle v7.7.0.
    Ideas?
        - Chuck
    Talk to your board house on how they want it.
    Add slot or oval to milling layer and add polygons for copper.
    Send notes to the effect of what you want before you order.
    Paul
