Forum how to draw a custom pad?
  • Views 463 views
huayuliang
huayuliang over 16 years ago
In many case, we need a not standard shape pad, such as rectangle hole, or a pad that have some vias on it.
how can do it? I thought use milling layer draw it, but I don't know how the PCB factory know it?
  • huayuliang
    huayuliang over 16 years ago in reply to Richard_H
    thanks your reply,  I'm understand....
  • Richard_H
    Richard_H over 16 years ago
    if you have to use rectangular holes, you should draw the contour in layer 46, Milling. Use the WIRE command with a very fine wire width for it. In case you are simply sending the BRD file to your board manufacturer, it is of course recommended to tell him  that there are contours in this layers. If you decide to generate manufacturing data by yourself with CAM Processor, generate one Gerber file for layer 46, Milling and pass it on with all the other Gerber and Excellon files.
    Richard Hammerl
