Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51342 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    Hi Brian,
    now I got them. I will look into them asap and come back on you....
    Richard
    Hi Richard,
    I'm using Eagle 4.16r2 and have a question about pads.  Our board house sometimes flags errors on pads and vias because the gerbers that are generated issue donuts and their DFM check may see a gap between the hole and the copper.  They would prefer we generate gerbers of copper layers with solid thruhole pads which, according to them, will eliminate the false hits.  I have not been able to figure out how to do this.  I want the drill hole visible during layout an DRC but would like to be able to issue filled pads in the gerber generation.  Thank you in advance.
    e14 Contributor over 15 years ago in reply to Richard_H
    Hi Richard
    Please find attached eaglerc.usr and eagle.scr files.
    Many thanks
    Brian.
    BRIAN HEATH
    SENIOR ELECTRONICS ENGINEER & PRODUCTION MANAGER  | TRAPEZE GROUP (UK) L
    TD.
    The Mill, Staverton, Trowbridge, Wiltshire, BA14 6PH
    Tel: +44 (0) 844 5616771 | Mobile: +44 (0) 7824310387 | Fax: +44 (0) 1225
    784206
           Brian.Heath@trapezegroup.co.uk   |   www.trapezegroup.co.uk
    eagle.scr.zip
    eaglerc.usr.zip
    Hi Richard
    Have you received the files from me yet, if not whats the best way to get them to you?
    regards
    Brian.
    Hi Richard
    I replied to your email I received as I did not know how else to get the attachments to you.  It went to communities@element14.com  I have now forwarded it to you at support@cadsoft .de hope this works.
    Regards
    Brian.
  • Richard_H
    Hi Brian,
    did not get your mail yet... Where did you send it to? support @ cadsoft.de ?
    Richard
    Hi Richard
    I have sent these by email, hope you get them ok.  Let me know if you donot receive them.
    Brian.
  • Richard_H
    Richard_H over 15 years ago in reply to tubesman
    Hi Bennett,
    our "librarian" who is creating our libraries is currently not in the office so I can't ask him about the 6mm spacing. You could modify the packages for your purpose so that you have them with a 10mm.
    I did not find a MAX668 in the libraries available. Sorry, you have to create it by yourself or maybe post a request in the EAGLE forum I already mentioned in the answer before.
    Best regards,
    Richard
  • Richard_H
    Hi Klaus,
    I am sorry I think this components are not yet available. You could post a question in the EAGLE support forum. Maybe one of the users already designed this.
    You can access the EAGLE groups directly via nntp  news://news.cadsoft.de or you can use the mirrored groups
    here at element14.com (Forums).
    Richard
  • Richard_H
    Hi Brian,
    could you please send me the eagle.scr file by email so that I can check this here?
    Richard
