Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51348 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    you can have inner layer with signal wires only or you can have inner layers with additional polygons. In terms of distortion, electromagnetic compliance, high speed designs and so on it can be helpful to use polygons. This depends on the project you are designing.
    Richard
  • Richard_H
    Hi Yash,
    the drill size and the via diameter are related through the restring settings in the Design Rules. Smaller drill sizes can result in smaller diameters of the vias. So please check this. If it is okay, you can ignore the DRC errors. Or you simply change the Min. drill value in the Design Rules.
    Concerning minimum distances and wire width for prototyping: I am not experienced in this so I can't be helpful in this subject. please post a message in the EAGLE Support forum. I think you will get a quick and proper answer from one of our EAGLE users there.
    About the setup of multi layer boards you should take a look into the EAGLE manual. There is a chapter dealing with this subject.
    Richard
    e14 Contributor over 15 years ago in reply to Richard_H
    Hello Sir,
    I meant if i route a signal in an inner layer and not draw polygon for that signal, will it affect the working of my PCB in any way??
    Thank You,
    Tkhan
    I had some queries about a project I've been designing in Eagle:
    1. I'm getting DRC errors if I keep the drill size of my vias at  proto(or lesser than) 0.6 mm. Does this drill size cause any problems during prototyping?
    2. Also, can I safely pass a route between two pins of a 0805 passive component without risking a short while prototyping?
    3. Similarly, would it be safe to pass a wire between two pins of an SOIC chip?
    4. I want to fit my circuit in as little space as possible. Could you direct me to any online/offline tutorial to creating multi-layer PCB's in Eagle?
    e14 Contributor over 15 years ago in reply to kemmi
    Maintain up the excellent perform people this really brilliant.
    Regards
    Lam Lam Article Writter For
    yahoo answers service
    mobile coffee cart
  • Richard_H
    I am not sure what you would like to ask. Could you please clarify?
    Thank you
    Richard
    Hi Sir,
    I just had a small doubt which i feeel i should better clarify...
    If suppose except of drawing a polygon in an inner later, i just route it inside then will it affect my PCB in any way???
    Thank You
  • Richard_H
    Hi again,
    that's great to hear that you finshed your project.
    It's always a pleasure if I can help.
    Richard
    Hello Sir,
    I am done with my PCB and it is approved.
    All thanks to you sir.
    This is how my Power and Ground layers respectively, look like
                   Thank you for your help Sir.. image image
  • Richard_H
    Hi Marvin,
    it is possible to import simple bmp images into EAGLE. There is import-bmp.ulp you can use. Best is to have black/white graphics because each color uses one layer in EAGLE.
    For more illustrative imges it might be better to do it the other way round. As you suggested: Export the Schematic and add the image later. .....
    Richard
