Forum Updated pinheader.lbr
  • Views 3227 views
  • pin
  • pins
  • pin_headers
  • pin_header
Hi
I required some single-row headers with octagonal pads for a project. Didn't find a suitable library so i modified eagles default pinhead.lbr library to include octagonal pads for all single-row headers. Also made some minor updates around naming to make it easier for future scripts to modify this package further.
Feel free to use and hopefully it can replace eagles default pinhead library since this contains everything from the original library + more.
// Rikard
Edit: See my post below for details on the latest update
Edit 2: Not sure how i missed this package before. http://www.cadsoftusa.com/downloads/file/pinhead-2.lbr this also contains SMD packages for the headers. Why isn't this a part of the default library which comes with eagle on installation instead of the current one?
pinhead_v2.zip
    Small update:
    I have also included lockable packages for pin header 1X02 to 1X20 (higher pin counts seemed unreasonable). Basically same as con-molex.lbr package 22-23-2xxx but i added this option here as well to keep everything in one place and to make it easier to change between different styles during design.
    6204.pinhead_v2.zip
