Forum Eagle Mac OS 7.5.0 - Open multiple schematics
  • Subscribers 187 subscribers
  • Views 456 views
eryk_spinar
eryk_spinar over 10 years ago
How can I open multiple schematic and board files in eagle on MAC OS?
Currently when I open one schematic for one project, and attempt to open another, the first one is being closed automatically so I cant compare them side by side.
I dont have this problem on Windows? Or am I doing something wrong?
Thank you
Eryk
  • Richard_H
    Richard_H over 10 years ago
    HI,
    you can open only one pair of schematic and board. And one library file and a "unlimited" number of text editor files within one EAGLE instance. As far as I know MAC OS does not allow two instances of one application at the same time by default.
    Searching in the web gave a solution for this (with Textedit.app as example):
    If you use open from the command line you can pass a parameter to start a new instance:
    open -n /Applications/TextEdit.app
    Another way is to find the Unix executable in the app bundle and run it:
    /Applications/TextEdit.app/Contents/MacOS/TextEdit &
    Hope this helps.
    Richard
