Forum Prevent Bus Auto-Numbering
  • Views 702 views
heedaf
heedaf over 15 years ago
Can anyone tell me how to prevent a bus from auto-numbering when copying a circuit?
DeWayne
  • Richard_H
    Richard_H over 15 years ago in reply to heedaf
    Hi again,
    you are right. A label prevents renaming nets and busses.
    Richard
  • heedaf
    heedaf over 15 years ago in reply to heedaf
    I found the solution. If you label the net then it won't auto number for any copies that are done.
  • heedaf
    heedaf over 15 years ago in reply to Richard_H
    I'm using 5.1.
    I copy everything since I want a duplicate circuit. I group-->copy-->paste and then my SCL net becomes SCL1. I would think that if you CUT it would keep the same everything since it isn't being duplicated.
    DeWayne
  • Richard_H
    how do you copy the bus and which EAGLE version do you use? Do you copy only the bus line or do you copy the nets as well?
    If I use, for example,  GROOP/CUT/PASTE for copying a bus it is not renames but keeps its name.
    Richard
