Forum BGA & microvia howto
  • Subscribers 187 subscribers
  • Views 658 views
Hi Richard,
I use Eagle software V6.2.
It is the first time I route a BGA component and I have difficulties to use the "route-bga.ulp" tool.
I get more then 400 DRC errors ! 2 types of error are listed: "drill distance" on layer 20 and "overlap" on layer 1,15 and 16.
See attached files for more details
Thanks by advance for your help.
Fabrice.
myfiles.zip
  • Richard_H
    Richard_H over 14 years ago
    Hi Fabrice,
    it is not easy to find out what the problems are without having the orignal brd file, but there are some suggestions I have:
    1. please check the layer setup. You used  (((1*2)*3)*(14*(15*16)))  which is no good choice.
    This way EAGLE can't use micro vioas because there are none defined. You defined only through hole vias.
    My suggestion is:   [3:(1+(2*3)+(14*15)+16):14]  The brackets [] define blind vias, which can be used for micro vias too.
    2. Change the value for Via-SMD for Same signals to 0. So no errors should be reported for vias on SMDs.
    Hope this helps.
    Richard
