Forum Eagle library for audio connectors?
  • Views 3552 views
  • eagle
  • audio
  • connector
  • footprint
  • library
  • pcb
beic
beic over 9 years ago
Hi there,
I'm trying to find any of bellow listed footprint for audio connectors in Eagle CAD and I can't believe that there is no such of it.
A few of them are standard (old style, maybe 10 year old layouts) but I can't find nothing similar searching under libraries.
List of PCB connectors in PDF downloadable format:
1. PJ-307-3 (3 pin) 3.5mm pcb socket
2. PJ-307-5 (5 pin) 3.5mm pcb socket
3. PJ-324M (5 pin) 3.5mm pcb socket
4. PJ-313D (5 pin) 3.5mm pcb socket
I hope someone can help me to find some of the mentioned footprints/library.
Kind regards,
Viktor
  • imperatore
    0 imperatore over 8 years ago in reply to imperatore
    Sorry, there are errors in some words.
    Please read:
    If you see the datasheet then you can see that the pins aren't circular.
  • imperatore
    Hi friends!
    I am trying to found a solution for PJ-324 connector.
    If you see the datasheet then you can pin that the pin aren't circular.
    I made a pad using the polygon. But now I have two problems: the first is that I am seen as a Wire so I can not associate a number to the pad, the second is that I have to move it as if it were a group otherwise change its size.
    I have had to do so for get a pad with a long, narrow hole, not circular.
    I have not simply superimposed two areas of copper on sides 1 and 16 followed by holes for two reasons: I need the hole to be metallized, the hole should not be uneven.
    How can I make a pad of this type?
