Forum external wiring for LTC3588 chip
  • Views 441 views
  • external wire
  • ltc3588-1
jim1995
jim1995 over 8 years ago
Hi, im pretty new to the eagle software and am in need to make a PCB for my LTC3588 chip. As the LTCC3588 chip is rather small (3mm x 3mm), i would like to place it on a PCB and connect external wires for use.  how am i to place external wire  to the PCB using the eagle software? would appreciate your help very much.
    0 genebren over 8 years ago
    Patrick,
    There are a lot of pin headers (pinhead.lbr) that can be used as wiring points. Most of these are either single or dual rows with 0.1" spacing between pads.  You can directly solder wires to these points fairly easily or you can add header pins (like those used on a lot of development boards) and use jumper wires.
    Good luck.
    Gene
