Forum how to draw a switch symbol
  • Subscribers 189 subscribers
  • Views 3502 views
faad021
faad021 over 8 years ago
Hello everyone,
How can one create such type of symbol with eagle ? I am trying to create a triangle metal dome switch library and i will like to know how to create this symbol.thanks
  • luislabmo
    0 luislabmo over 8 years ago in reply to faad021
    Hello Leroi,
    I think you can try the tutorials genebren suggested in one of your previous post, or here is an Adafruit step-by-step tutorial as well. Another thing you may try is to create a part using an existing package and modify it to your needs. A Momentary NO (normally open) SPST push button switch may work for you.
    Luis
  • faad021
    0 faad021 over 8 years ago in reply to luislabmo
    hi Luis,
    I am trying to create a library for a triangle metal dome switch. Here is the link to the datasheet
    https://files.elv.com/Assets/Produkte/2/243/24380/Downloads/24380_TDW_data.pdf
    I would really appreciate if someone can help me with this.
    thanks
  • luislabmo
    What exactly do you need help with? How to create a symbol in eagle ? or do you need help knowing how to recreate that symbol with the tools available (Arc, Circle) ?.
    Also I may advise to use a more common symbol for a switch which is widely available in many libraries, that dome seems to behave like a push button, something like this:
    Luis
