Forum Eagle GND plane not showing after Ratsnest comand
  • Subscribers 187 subscribers
  • Views 1199 views
anonym2016
anonym2016 over 7 years ago
I want to pour GND planes on both TOP and BOTTOM layers.I placed 2 poligons(1 on top 1 on bottom) but the ground plane does not appear after i press ratsnest either from selecting the poligon right click or the left panel command.
Also the AutoRouter didn't want to route my signals,it started but it displayed as 00.0%.I did the routing manually in the end.DRC only shows Dimension errors but i belive they can be approved without much trouble.
One last thing i'd like to check is if it's the board manufacturable as it is(are the vias too small,clearance is ok,other things i may have forgotten).
Thank you.
Mini_cube.zip
  • anonym2016
    0 anonym2016 over 7 years ago
    Found out that if you draw a dimension polygon over it does not work.Now it works as it should.
