Forum Spreading parts across differents sheets...
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 1247 views
  • cut
  • eagle
  • problems
  • paste
Hi everybody!
I'm having some troubles here when trying to do some tasks in eagle. I'm currently working with a free version of Eagle (4.16r2 Light).
The problem comes when I try to use diferent parts of the same component in different sheets. I work with relays and in order to keep organized the sch, i would need if possible, to have the coil command circuit in one sheet, and the contacts part in other different page. I have tried to cut and paste the parts I want to be in the other sheet ,previously deleting the selected parts so I dont have duplicated parts... but Eagle don't care and duplicate them wherever I paste them...
I would appreciate any suggestion!!!
    0 e14 Contributor over 16 years ago in reply to Richard_H
    Yeap! Im editing this in my PC and I dont have a license available for me yet... if you open a multi sheet document in eagle light it works with some limitations...
    Any way... I guess that even having a licence for this version runing in my PC, It wouldnt be possible to do what I need image
    Richard.-
  • Richard_H
    0 Richard_H over 16 years ago in reply to e14 Contributor
    By the way:
    EAGLE Light can't have more than one sheet in a schematic.  ???
    Richard
    I'm currently working with a free version of Eagle (4.16r2 Light). image I cant update to 5.x because the rest of the team is already working with this old version...
    Richard.-
  • Richard_H
    What's the EAGLE version you are working with?
    Is it version 5.x? If yes, go to the Options/User Interface menu and activate "Sheet thumbnails".
    -Richard
    Hi Richard, I was investigating and I realised that my version of Eagle does not support what you suggest... which is a pitty because it seems to be a really good improvement... but I guess I have no choice and I have to stick to this older version... any other suggestion?
    Thanks!
    Richard.-
    Hi Richard, once again, thanks for your help!
    Could you  explain me more specificaly how should I proceed in this part:
    click onto the sheet into the preview where you want to place the objects and click to place them
    Thanks!
  • Richard_H
    You could move the component from one sheet to another without loosing the layout. Simply do GROUP to select the part (even if it is one single element, then use MOVE and a right mouse click into the drawing (the objects follow the mouse cursor now), click onto the sheet into the preview where you want to place the objects and click to place them.
    HTH
    Richard
    Hi there! Thanks for answering so soon!
    I tried what you say and works perfectly!!... The problem is that the sch is already done... and there are a big number of parts already placed... so I guess that redraw it wouldn't count as the last option... image.
  • Richard_H
    Hello Richard,
    to spread components over several sheets, you have to use the INVOKE command. Activate INVOKE and type in the part name  in the command line. Hit <enter> and a menu appears that shows you the available gates of the part.
    HTH
    Richard
