Forum power layers
  • Views 342 views
power layers
I've tried for a week or so and cannot get the inner 2-3 layers to auto gen as power layers, I tried locating an example four layer board to no avail.
Does anyone have a "throwdown" example I could view. I have the standard edition.
I named layer 2 GND and layer three VCC33. The power nets in schematic are named like this. The layers 2 and 3 are selected as supply layers.
Bruce
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    Bruce,
    On the board, make sure you don't have your layer names prefixed with a '$' sign. If you double click at a layer from the Layer "Display" button, you will see a check box for supply layer. If it is checked then EAGLE automatically assigns a $ sign with the name.
    -Jaya
    Have you tried doing it as a polygon? That's how I do ground planes (not needed a power one, but the principal would be the same).
    Basically, make a polygon in the layer you need follow the shape of the board, and then tell it what signal to 'attach' to.
