Forum Cant find the PLCC-44s package in Eagle 5.10
  • Views 760 views
  • eagle
  • pcb
  • plcc
  • cadsoft
I used to use the 'plcc-S44' package from the 'IC-Package ' library in earlier versions of Eagle.  I cant seem to find it in v5.10.
Its a 44 pin through hole adapter for a PLCC package [XC9532]
I tried looking through all the libraries manually, but no luck.
Does anyone know where to find it, or perhaps, if you are running the old version, could you please mail the library in question to me?
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    Thank you so very much.
    Please find attached a library. There are a couple of PLCC-44 packages. Probably you would have to double check the dimensions etc...
    Best Regards,
    Jaya
    PLCC.zip
