Forum Schematic not showing all pins on device
  • Views 643 views
I am attempting to use the 74LS373N DIL20 device in the 74xx-us library that you can download from Eagle.  When I add the device to schematic, it shows all pins, except 10 and 20.  I have included pictures to demonstrate what I'm trying to show as the problem.  There are two schematic symbols that are supposed to show up when you add the device to schematic, the data pins, and the power and ground.  It doesn't show the power and ground pins.
Can anyone tell me why this is happening?
-Eric
    0 e14 Contributor over 15 years ago in reply to Richard_H
    Thank you Richard, that did the trick!
  • Richard_H
    0 Richard_H over 15 years ago
    Hi Eric,
    it is possible to create devices that consist of several symbols and you can decide how to place them in the schematic (Addlevel). Lot of devices have the power pins hidden. To get them visible in the schematic use the INVOKE command (it's represented by an icon that shows kind of four gates) and click onto the symbol (or type in its name in the command line). Now you get a table with available gates you can place.
    Regards
    Richard
