Forum File Conversion
  • Subscribers 187 subscribers
  • Views 358 views
  • eagle
  • to
  • pads
  • pcb
File Conversion
I have a couple of old projects in PADS, is there a conversion to Eagle?
K
  • Richard_H
    0 Richard_H over 14 years ago
    Hi K,
    there is one data format that comes into my mind. Do you have the possibility to export ACCEL-ASCII data? If
    yes we could try to convert it into EAGLE with the help of a ULP which is currently developed. The ULP is not yet publicly available, but if you would likie to test it I could send it to you.
    Basically EAGLE gives us all the tools to write import or export filters in order to exchange data to other layout tools.  We offer the possibility to access to the whole EAGLE data structure via our User Language. So it is no problem to have an ULP for converting EAGLE data. If you would like to write a proper ULP for converting data  from another layout tool into EAGLE you need a proper and full documetation of the data format.
    By the way: There recently was a posting in one of the EAGLE newsgroups which addressed conversion services. I simply add it here (I am not affiliated with this company):
    -------- Original Message --------
    Subject:     re: EAGLE Imports/Exports with LogicSwap
    Date:     Thu, 8 Jul 2010 11:11:21 -0400
    To:     <sales@cadsoft.de>
    *PCB Library Import / Export*
    In many cases you may be selling the EAGLE tool into a group within a
    company that already has other PCB Design tools and an existing PCB
    Library of Parts.
    Rather than create another Library from scratch in EAGLE, it would
    benefit the customer to be able to Import the existing Part Library into
    the EAGLE tool.
    This could save weeks or months of time depending on the size of the
    library. Conversely, the customer may have built several parts in EAGLE
    and would like to Export them to the corporate Library which is a
    different EDA/CAD tool.
    *Schematic & PCB Design Import / Export*
    Some companies have existing Design IP (Schematic and /or Board Design)
    or have downloaded a Reference design that exists in another EDA/CAD
    tool format and want to import that IP into EAGLE.
    Others may have designed some IP using EAGLE and want to share it with
    other groups or partners that have a different EDA/CAD tool.
    LogicSwap specializes in Importing into EAGLE and Exporting from EAGLE.
    Should you have a situation where you or your customer needs some help
    in EAGLE Import / Export, please contact me to discuss.
    For technical questions, please contact Dilip Patil at 781-560-8170 or
    dpatil@logicswap.com <mailto:dpatil@logicswap.com>.  Our website is
    www.logicswap.com <http://www.logicswap.com>.
    Best regards,
    Mike Wilson
    LogicSwap
    PCB Software & Services
    215.368.5817
    267.971.7300 (Cell)
    mikewilsonpcb@comcast.net
    Skype=mike.wilson147
    YahooIM=mikewilson19422
    Richard
