Forum Deleting all traces on a board.
  • Subscribers 187 subscribers
  • Views 17459 views
Hi Richard,
After I have routing a double sided board with the autorouter in Eagle 6.2. There  remains a number of traces not routed.
They should be implemented manually. But the space between the components is to small.
I would like to delete all the traces, give a little more space between the components and then let autorouter routes the traces again.
However I can’t find how I can delete all traces.
Can you explain this to me?
    0 e14 Contributor over 14 years ago in reply to Richard_H
    Hi Richard,
    Thank you for your response.
    It was very helpfull for me.
    Thank You very much.
    Kind regards,
    Jo.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Hi Ivan,
    Indeed in V6.02 you also use the Ripup command to delete  traces. However to delete all traces at once, you do it with an click on Ripup and than click the traffic light (GO command).
    For me it was very helpfull to learn the connection between DELETE and RIPUP.
    Kind regards,
    Jo
  • Richard_H
    0 Richard_H over 14 years ago
    simply type in command line
    RIPUP ;
    Then EAGLE asks to ripup all signals. That's it.
    Richard
    Hi Jo,
    I'm currently using Eagle v5.11.0, but, hopefully, the same steps are applicable also in v6.2...
    To delete all traces, perform the following steps:
    1) click "Ripup" icon
    2) click "Group" icon
    3) mark the area you'd like to delete all traces within (whole PCB in this your particular case)
    4) click right mouse button and then select item "Ripup: Group" in shown menu.
    Best wishes,  Ivan.
