Forum Removing un-used signal names in .brd file in 6.2.0
  • Subscribers 187 subscribers
  • Views 399 views
  • eagle
  • pcb_layout
  • software
I like version 6 because one can paste other board layouts onto a new board without loosing the layout.Then, the parts that are not required for the new design can be deleted.
However, I noticed that the .brd file was getting much larger than the schematic.  Upon looking at the XML, it appeared as if un-used signals were not being deleted.
Although it was easy to go through the file and delete the un-used signals, shouldn't this be done automatically when the file is saved?
  • Richard_H
    0 Richard_H over 14 years ago
    as soon as you delete a signal in the project it should no longer appear in the board or schematic file.
    Are you sure that you deleted the whole signal? Do you still have board and schematic files before you deleted the signals manually? If yes, feel free to send them to me by private email to  support @ cadsoft.de. So I could try to get out what happened.
    Richard
