Forum How can output negative eagle CAM
  • Views 810 views
The CadSoft EAGLE upgrade to V6, the abolition of the supply layer, when I draw a 4-layer supply layer polygon can be connected to the corresponding signal, this is normal? How can I be able to the CAM output layer negative Gerber files?
    0 e14 Contributor over 13 years ago in reply to Richard_H
    ok, I understand
    thank you!
  • Richard_H
    0 Richard_H over 13 years ago in reply to e14 Contributor
    If you create Gerber data, let's say for a 4 layer board, you need for example
    Top + Pads+ Vias             for the top side
    Layer2 + Pads + Vias      for 1st inner layer (if you used layer 2 for it)
    Layer15 + Pads + Vias    for 2nd inner layer (layer15 here)
    Bottom + pads + vias       for the bottom side
    and so on........
    Each layer combination result in a separate gerber file.
    Richard
    Do you mean the same toplayer output is not it?
  • Richard_H
    EAGLE version 6 does no longer support inverted supply layers, as it was in the previous versions. Now you simply have to use a polygon in the inner layer, for example, for a ground plane. For creating Gerber data you have to output the inner layer + Pads + Vias into one Gerber file. It is the same as if you would export Top or Bottom side.
    The CAM Processor does not (and it is not necessary to) export Gerber data inverted.
    If you want to have an inverted output for example in Postscript format, let's say for a photo plotter, then you could use the PS_INVERTED device.....
    Hope this helps.
    Best regards,
    Richard
