Forum Parts added to schematic do not show up on board layout in EagleCad light 6.4.0
  • Replies 8 replies
  • Views 5407 views
japper
japper over 13 years ago
I am using the Eagle 6.4.0 light version and created
a schematic and PCB layout a few months ago.
I just recently returned to this schematic and
opened both the schematic and the board layout.
I then added a few components to the schematic
but the board layout did not pick up the parts
that I added to the schematic.
Is there a way to get these parts added to the
board as well so that they are tied to the schematic?
thank you
  • japper
    0 japper over 13 years ago in reply to Richard_H
    Thank you Richard-
    I had some traces hiding under some devices...
  • Richard_H
    0 Richard_H over 13 years ago in reply to japper
    Hi japper,
    there seem to be different situations at pins and referring pads. The message tells me that there is a net with name N$50 assigned to pad 2 (in the layout) of J3. In the schematic the referring pin is pin2 and there seems to be no net connected.
    Please check the layout with SHOW N$50. Is this net highlighted? Did you display all signal layers before you deleted the signals in the board?
    Richard
  • japper
    Thanks Richard-
    In deleting certain parts, I am left with several messages (for different parts)  that state:
    Different connections on J3-A pin2 and Pad 2 (none /N $50)
    I can see a part on my schematic and the corresponding part on my board layout but I am not sure
    how to resolve these errors. I have deleted all of the traces going to these parts.
    How do I resolve these errors?
  • Richard_H
    yes you  have to either add the missing components in the board or delete them in the schematic. Depending on what is less effort. You have to make board and schematic consistent. After that back and forward annotation will work again.
    Richard
  • japper
    0 japper over 13 years ago in reply to japper
    Does anyone know the answer to this?
    3. Jul 10, 2013 10:21 AM (in response to Jeff Pipitone)
    Re: Parts added to schematic do not show up on board layout in EagleCad light 6.4.0
    I ran the ERC and corrected all of the errors and then opened the board and ran ERC again.
    I get a message box stating "Board and schematic are not consistent! No Foward/backannotation will be performed!"
    After clicking the OK button, a list of parts not found in the schematic or on the board appear in the list
    with a clear all or processed button. (I actually changed a few parts too which expalins why some were not found on the schematic...)
    Do I now have to manually add these parts that I added to the schematic to the board layout?
    thanks.
  • japper
    thanks.
    Message was edited by: Jeff Pipitone
  • japper
    Thanks for the tip Richard.
    I will try that later tonight when I am at home
  • Richard_H
    first thing you have to do is to run a ERC. Does it report consistency? If not, check the differences and try to make board and schematic consistent again. Only then Forward/Back annotation will work.
    Richard
