Forum Cam processing of existing board files
  • Views 868 views
Hello Richard,
I have a number of old Eagle boards, without Gerber files. I have no version of Eagle installed now, but from years ago I think the CAM processor was removed from the layout software and could be used outside the license structure. Is this so still, and is it possible to download the CAM processor from somewhere? I need to make Gerber files from the existing boards. They are made with version 3.55, if that is important.
Thanks for all support.
TOK
    In my opinion ,when you get the gerber file ,you can think about  the next!......
    what the hell with you!
    0 e14 Contributor over 13 years ago in reply to Richard_H
    I can't open your link, but I tried it on other, this is good
    facebook:https://www.facebook.com/?sk=nf
    As far as I know, as long as there is gerber file, can produce the circuit diagram of ah, you can try this   http://pcb.hqew.net/?s=544864, I am also the gerber file directly and then solve the problem
  • Richard_H
    0 Richard_H over 13 years ago
    HI,
    each EAGLE version comes with the CAM Processor. Simply download the current EAGLE from our web site, use it as Freeware and generate manufacturing data with it. The CAM Processor of the Freeware can handle boards from higher editions as well. If you need an older version of EAGLE, look at ftp://ftp.cadsoft.de/eagle/program.
    Best regards,
    Richard
