Forum how to copy/paste a section of layout/schematics pairs finished?
  • Views 1069 views
I have a  schematics/boards pairs finished .
For example a schematic/board pairs with one preamplifier and one amplifier.
I want to add on this actual board 3 copy of the preamplifier that is already present .
How can I do that ?
....Of course I want to keep a pair of consistent schematics / boards ...
Best regards.
Pierre
    0 e14 Contributor over 13 years ago in reply to Richard_H
    Thank you for your prompt reply.
    I have used this method already .
    But for a complex board with many sheets if you want differents parts : this is a hard solution ...
    Thank you again for everything you’ve done.
    Best regards.
    Pierre.
  • Richard_H
    0 Richard_H over 13 years ago
    copy you schematic and board that contains preamp and amp.
    Then delete everything except the preamplifier. Now save this as preamplifier board and schematic (they are consistent).
    Now open your target project (amp +preamp) which is also consistent
    Go to Edit/Import/EAGLE drawing... in the layout editor or in the schematic editor and select the preamp brd or sch
    Now the preamp is inserted into sch and brd.
    Repeat this as often as necessary.
    That's it.
    Richard
