Forum Hide ORIGIN markers on Text items in Eagle PCB/Board file
  • Subscribers 187 subscribers
  • Views 1128 views
  • eagle
  • pcb_layout
  • layers
zaidpirwani
zaidpirwani over 12 years ago
if you see the attached file, you will see my problem, I have hidden the layers tOrigin and bOrigin but still origin marker is showing on text.
Also when exporting image using export, then selecting image, the PADs are exporting as filled.
Please HELP...
  • Richard_H
    0 Richard_H over 12 years ago
    If you would use the PRINT command to print your layout (also as a pdf file), the drill holes should remain open. The origin crosses of the texts won't be exported either.
    EXPORT IMAGE works different, as it uses a kind of print screen for it....
    Richard
