Forum Eagle: Cannot have "Ground Plane" on Bottom layer!?
  • Views 714 views
I am learning Eagle and now cannot resolve some trivial problems. I have made minimalistic PCB with 3 elements on it. Board is intended to be one-side copper (Bottom) and one-side components (Top).
Now, when I want to make "Ground Plane" on Bottom layer - make polygon > name it "GND" > click on it again > "Ratsnest" > and ... I have nothing.
When I do that on "Top" layer - when I make "Polygon" on "Top" layer, I can easily do it and I can have "Ground Plane" on "Top" layer.
But, I need it on "Bottom" layer....
What am I missing here!?!
    0 e14 Contributor over 12 years ago in reply to Richard_H
    Ok, I have checked things and found out that "naming" of nets was inconsistent... when I have put correct names to nets it do the job...
    Thank you on your hint.
  • Richard_H
    0 Richard_H over 12 years ago
    maybe there are no ground pads or vias inside the polygon area? The copper area can't be connected to anything and therefore nothing is visible????
    Richard Hammerl
