Forum Group Does Not Work
  • Views 519 views
Group Does Not Work
According to the Manual Version 7, 2nd Edition, page 57, one should be able to use the Ctrl and Shift keys to toggle membership in a defined group:
If you like to add further groups to an already existing one, press the Shift key and define the first corner of the selection area with a mouse click.
In case you want to add an object to or remove it from the group, press the Ctrl key and click onto the object in question.
Press Ctrl + Shift to toggle the membership of an object and its hierarchically superior objects: Clicking for example, on a net segment in the Schematic
inverts the group membership of the whole net.
I cannot get the keys to function as described, either with a real schematic or just a simplified example consisting of 4 capacitors.  What is the trick to get it to work as described?  Is there a video demonstration showing those functions?
    OK, I think I got the CTRL key figured out to add or subtract from a group.  A bit clumsy, but it works.  You have to keep re-selecting the group icon.  For example, if you have move selected, then group.  The program reverts to move once the group is selected.  You need to re-select group to add or subtract from the group.  At least, it works with simple objects that have distinctly marked origins.  John
