Hi all,
I would like to explore this version for educational purposes, but I can't find it on the web.
Could someone please point me to a link where I can get this version of CadSoft Eagle 4.14 if it still exists?
Best regards.
Hi all,
Best regards.
Hi Amilcar,
yes I remember me. That was a time in happy electronics.
Here is a circuit of an interpreted of the KITTs scanner lamps.
And the project files, saved in Eagle version 7.7.0:
Best Regards
Gerald
Hi Gerald,
You are right, this is indeed the circuit to reproduce the KITT effect. What good times.
Where I am at the moment I cannot edit your schematic but I would suggest saving two diodes, D1 and D10, as there will never be a return signal in these two lines.
Once again, thank you very much for sharing.
All the best.
Amilcar
well, yes. You can saving or not. The diodes make an "serial resistor" about few Ohm's at about 1 volt.
May be then that LEDs may lightning a bit brighter without the diodes.
If you want to saving, just use a wire bridge instead of the two diodes.
