Forum AD9850 DDS MODULE
  • Subscribers 187 subscribers
  • Views 1665 views
AD9850 DDS MODULE
bluetang2
bluetang2 over 8 years ago
There are two types of AD9850 DDS Module: Type 1 (on the top) and type 2 (on the bottom).
I need a library with the footprint of type 2 module.
Any help?
    shabaz over 8 years ago in reply to bluetang2
    That information was not in your original question.
  • bluetang2
    bluetang2 over 8 years ago in reply to shabaz
    I'm able to create any part in Eagle. I have already created lots of them. The issue is that I don't have the complete information of the module board (dimensions, etc). I ordered the board but haven't received it yet. I'd like to start drawing my project before it arrives.
    That's the compromise; either a custom design can be created with outlines, holes and whatever you fancy, or you can use two SIL headers. The first option entails some work from you I'm afraid. If you're interested, then the procedure is to read up (or google and watch) videos on 'EAGLE CAD part creation'. If you google those exact words, you'll find what you need. Or you could try the hack approach of adding your own holes and outlines to the board view. Not pretty.
  • bluetang2
    Yes, but I need the board outline and mounting holes too.
    You can use two SIL header pins for this, if you really don't wish to design your own package (although it is only a 5-minute task to google a video, watch it, and then 20 minutes practise before you create your own).
    If you wish to use SIL header pins, you'll find the header pins in con-lstb library.
