Forum Single layer board
  • Views 654 views
Single layer board
mikroq
mikroq over 8 years ago
I'm not sure if this is possible or not. I'm trying to make an electrostatic pad. I just need a honeycomb copper design on top of the PCB board. I
I would like to send this off to be manufactured, but it doesn't seem like I can create only one layer on Eagle. I am a beginner with this software so any help would be greatly appreciated.
Thanks!
    genebren over 8 years ago
    There should be no problem creating a PCB in Eagle with only one layer.  I have not personally tried this, but I can't think of a problem doing it.  When sending out the gerber files, you might prepare a bottom layer that is blank, as a way to satisfy the PCB manufacturers submission requirements.
    Good luck,
    Gene
    dougw over 8 years ago
    You can choose not to put anything on the second layer or simply not send the Gerber file for the other copper layer to the manufacturer..
