Autodesk EAGLE
Autodesk EAGLE
Files The element14 Arduino CadSoft Library (Rev C)
  • Next
  • Previous
  • Author Author: joeman
  • Views 40055 views
  • Downloads 2634 downloads
  • Likes 20 likes
  • Comments 75 comments
We are pleased to offer our very own CadSoft library for Arduino--for free!  Our new library simplifies Arduino shield development by placing the most-popular Arduino pinouts right at your fingertips.  The latest version includes these boards: 101, Uno, Nano, Mini, Micro, Mega2560, Lilypad, Leonardo, Ethernet, and Due
Don't yet have CadSoft EAGLE?
Get your copy here!
Let us know what you think by posting comments below, and thanks for being a part of the element14 community!
  • pinout
  • arduino pinout
  • eagle_library
  • cadsoft
joeman
joeman
  • 28 Oct 2013
  • 2,634 Downloads
  • DaveYoung
    DaveYoung over 11 years ago in reply to cap269 +2
    Hi Andrew- This library references the MEGA2560. I think it could be labeled better, so I'll add that change to the next library revision. There are a few differences between the two on the pin headers…
  • tronixstuff
    tronixstuff over 12 years ago +1
    Well done, very useful.
  • DaveYoung
    DaveYoung over 12 years ago in reply to Workshopshed +1
    Hi Andy- This library has the Due, Ethernet, Leonardo, Lilypad, Mega, Micro, Mini, Nano, and Uno boards. Thanks for asking about the Micro Pro - it helps for determining which ones would be useful to add…
  • mot9112
    mot9112 over 11 years ago
    Having problems using these libraries in the free version of Eagle V7.2.
    Are these restricted to purchased versions of Eagle or am I doing something wrong.
  • DaveYoung
    DaveYoung over 12 years ago in reply to e14 Contributor
    You bet! I'm glad people are using it!
    e14 Contributor over 12 years ago in reply to DaveYoung
    Perfect! I'll try that tomorrow. And thanks for the Arduino Eagle library!
  • DaveYoung
    You mean replace the existing device in your current schematic/board files (since you've probably got the rest of the design partially complete)? Yes, I've found the easiest way to update a part is to go in the schematic editor and try to add another device (i.e. like you want to have 2 MEGA boards on your board). Just before it allows you to place it, it asks if you'd like to update all of the instances of the device in your design, which you can say 'YES' to.  It will then update the schematic and board with the new version of the device from the library. Then when it lets you place the second component instance, just don't place it anywhere (hit escape).
    You can also update the library or all libraries in a schematic by going to the Library menu > Update (or update all) and select what you want updated. I usually prefer not to do this in case someone else has been fiddling with the library unexpectedly (Or I fiddled with it for another project and forgot).
    Good luck!
    Hi Dave,
    thanks for the advice. Is it possible to replace the existing device with the one i edited afterwards?
