Autodesk EAGLE
Autodesk EAGLE
Documents Microchip CAD Library for Cadsoft EAGLE Software
  • Author Author: atomar
  • Date Created: 9 Apr 2012 4:43 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:43 AM
  • Views 11680 views
  • Comments 24 comments
element14 provides consolidated Cadsoft EAGLE CAD libraries to reduces the efforts and time put into by our EDE customer in PCB design process while creating CAD Library for specific part in a design. The provided CAD libraries has both Symbols and Footprints (Device, Symbol & Package) information and developed as per IPC standards to meets all industrial PCB design requirements. Every CAD library has part information along with Farnell and Newark order codes which helps in creating final Bill of Materials with the suppliers order codes.
This EAGLE CAD library covers a wide range of Microchip device categories like EEPROM, DSP Microcontroller, Supervisory Circuit, Power Management, MOSFET, Voltage References, Transceiver, Encoder/ Decoder, I/O Expander, Voltage Converter, Digital POT, Operational Amplifier, Comparators, Amplifiers, Battery Management, Sensors etc. This library is provided in a downloadable ZIP format which includes below files:
1. Microhip library (.lbr) file
2. List of components in the library (PDF)
3. Readme file - Gives step by step instruction on how to import and use the library file into the Cadsoft EAGLE software.
imageMicrochip_Library_Components_List.pdf
Microchip.zip
  • mosfet
  • i/o
  • eagle
  • expander
  • management
  • digital
  • microchip
  • sensors
  • footprint
  • amplifier
  • EEPROM
  • converter
  • library
  • circuit
  • transceiver
  • cad
  • pot
  • amplifiers
  • battery
  • voltage
  • dsp
  • encoder/
  • microcontroller
  • operational
  • comparators
  • power
  • supervisory
  • symbol
  • cadsoft
  • references
  • decoder
  • lvignals
    lvignals over 12 years ago in reply to trfillos +1
    Hi TP, until you receive an answer from element14, you could upload the library to a git repository on github and post the URL here so people can start discovering the new parts you have created...
  • miciomax
    miciomax over 11 years ago +1
    Missing all pic32MZ family.....
  • tomstorey
    tomstorey over 9 years ago +1
    This library is 5 and a half years old, so it probably needs some updating.
  • tomstorey
  • ravihk19
    ravihk19 over 9 years ago
    I am not finding the Programmable Delay line components in the library please help me to get them. SY89296 and series components.
    Bonjour , je trouve pas PIC16F1508 SVP
    Attenzione una marea sono sbagliati , ad esempio ho rilevato MCP3302 risulterebbe un quattro ad ma è un doppio ad , l'operazionale MCP602-I/ST è un 14 pin quadruplo e dovrebbe essere un doppio a 8 pin , cosi moltissimi altri . ATTENZIONE anche sui pic ci sono errori , in alcuni ad i pin sono segnati con diversi , non li riporto uno per uno perchè sono troppi .
    WARNING : Lot of mistakes , verify carefully.
  • yvan-roch
    yvan-roch over 11 years ago
    When I try to download http://www.element14.com/community/servlet/JiveServlet/download/64255-1-101093/Microchip.zip, the download failed and I got this message:
    Error
    An general error occurred while processing your request.
    Could you repair that ?
    Thank you.
    I downloaded the library, and it says that it has the PIC16F84A in the component list, however, after including the library, I cannot find the component in the ADD window, help with this please.
  • miciomax
    Unfortunately no dsPIC33EP library image, So I have to make it by myself.
    but still good library
  • zaid2015
    zaid2015 over 11 years ago
    Thank you for uploading the library
    Thanks, saved me a lot of time!
